Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet HMC437MS8G, 437MS8GE (Analog Devices) - 4
ОписаниеSMT 4 SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz
Страниц / Страница6 / 4 — HMC437MS8G / 437MS8GE. SMT GaAs HBT MMIC. DIVIDE-BY-3, DC - 7 GHz. …
Формат / Размер файлаPDF / 362 Кб
HMC437MS8G / 437MS8GE. SMT GaAs HBT MMIC. DIVIDE-BY-3, DC - 7 GHz. Outline Drawing. Package Information. Pin Description. 4 - 4
HMC437MS8G / 437MS8GE SMT GaAs HBT MMIC DIVIDE-BY-3, DC - 7 GHz Outline Drawing Package Information Pin Description 4 - 4
23 предложений от 13 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ микросхемы и модули
Akcel
HMC437MS8GETR
от 2 847 ₽
HMC437MS8GETR
Maxim
2 954 ₽
HMC437MS8GETR
Allelco
HMC437MS8GETR
v05.1211
4 4 t t M M s s s - s - r r o o t t c c e notes: e t 1. LeADFrAMe MAteriAL: coPPer ALLoy t e 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] e 3. DiMension Does not incLuDe MoLDFLAsH oF 0.15mm Per siDe. 4. DIMENSION DOES NOT INCLUDE MOLDFLASH OF 0.25mm PER SIDE. 5. ALL GrounD LeADs AnD GrounD PADDLe Must Be soLDereD to s & D PcB rF GrounD. s & D r r e
Package Information
e iD Part number Package Body Material Lead Finish MsL rating Package Marking [3] iD iv HMc437Ms8G Low stress injection Molded Plastic sn/Pb solder MsL1 [1] H437 XXXX iv y D HMc437Ms8Ge roHs-compliant Low stress injection Molded Plastic 100% matte sn MsL1 [2] H437 XXXX y D c [1] Max peak reflow temperature of 235 °C [2] Max peak reflow temperature of 260 °C c n [3] 4-Digit lot number XXXX n e e u u q
Pin Description
q e Pin number Function Description interface schematic e r r F 1 vcc Supply voltage 5V ± 0.25V. F 2 in rF input must be Dc blocked. RF input 180° out of phase with pin 2 for differential 3 in operation. Ac ground for single ended operation. Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4 - 4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
