HMC1133LP5E v01.1216 GaAs MMIC 6-BIT DIGITALPHASE SHIFTER, 4.8 - 6.2 GHzOutline Drawing T M L - S ITA IG NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA S - D 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER R 50 MICROINCHES MINIMUM NICKEL. E 3. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE T 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM -C- 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE IF SOLDERED TO PCB RF GROUND. H 7. CLASSIFIED AS MOISTURE SENSITIVITY LEVEL (MSL) 1. Package Information E S Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] S HMC1133LP5E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL3 [1] H1133 XXXX A [1] Max peak reflow temperature of 260 °C H [2] 4-Digit lot number XXXX P Pin Descriptions Pin Number Function Description Interface Schematic 1 - 4, 6 - 19, No connection required. These pins may be connected to N/C 21 - 24 RF/DC ground without affecting performance. 5 RF1 This port is DC coupled and matched to 50 Ohms. BIT6, BIT5, BIT4, Control Input. See truth table 26 - 31 BIT3, BIT2, BIT1 and control voltage tables. 32 Vss Voltage supply. 25 Vdd Voltage supply. 20 RF2 This port is DC coupled and matched to 50 Ohms. Exposed ground paddle must be connected GND to RF/DC ground For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com 5 Application Support: Phone: 1-800-ANALOG-D
