Datasheet GBPC6005, GBPC601, GBPC602, GBPC604, GBPC606, GBPC608, GBPC610 (Vishay) - 2
ПроизводительVishay
ОписаниеGlass Passivated Single-Phase Bridge Rectifier
Страниц / Страница4 / 2 — GBPC6005, GBPC601, GBPC602, GBPC604, GBPC606, GBPC608, GBPC610. …
Формат / Размер файлаPDF / 84 Кб
GBPC6005, GBPC601, GBPC602, GBPC604, GBPC606, GBPC608, GBPC610. ELECTRICAL CHARACTERISTICS. TEST. GBPC. PARAMETER. SYMBOL. UNIT
GBPC6005, GBPC601, GBPC602, GBPC604, GBPC606, GBPC608, GBPC610 ELECTRICAL CHARACTERISTICS TEST GBPC PARAMETER SYMBOL UNIT
19 предложений от 12 поставщиков
Мостиковый выпрямитель, VISHAY GBPC601-E4/51 Bridge Rectifier Diode, Single, 100V, 6A, Module, 1V, 4Pins
T-electron
GBPC601-E4/51
19 ₽
GBPC601-E4/51
от 35 ₽
Элитан
GBPC601-E451
547 ₽
GBPC601-E4/51
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
TEST GBPC GBPC GBPC GBPC GBPC GBPC GBPC PARAMETER SYMBOL UNIT CONDITIONS 6005 601 602 604 606 608 610
Maximum instantaneous forward V voltage drop per diode F 3.0 A 1.0 V Maximum DC reverse current at TA = 25 °C 5.0 rated DC blocking voltage per IR μA diode TA = 125 °C 500 Typical junction capacitance per C diode J 4.0 V, 1 MHz 186 90 pF
THERMAL CHARACTERISTICS
GBPC GBPC GBPC GBPC GBPC GBPC GBPC PARAMETER SYMBOL UNIT 6005 601 602 604 606 608 610
RJA 22 Typical thermal resistance (1) °C/W RJC 7.3
Notes
(1) Bolt down on heat-sink with silicone thermal compound between bridge and mounting surface for maximum heat transfer with #6 screw (2) Unit mounted on 5.5" x 6.0" x 0.11" thick (14 cm x 15 cm x 0.3 cm) aluminum plate (3) Unit mounted on PCB at 0.375" (9.5 mm) lead length with 0.5" x 0.5" (12 mm x 12 mm) copper pads
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PACKAGE CODE BASE QUANTITY DELIVERY MODE
GBPC606-E4/51 3.2 51 100 Paper box
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 8.0 200 Case Temperature, T = T Max. J J T Heatsink Mounting Single Sine-Wave C 175 5.5 x 6.0 x 0.11" Thk. 6.0 (14 x 15 x 0.3 cm) Al. Plate rrent (A) u 150 60 Hz Resistive or Inductive Load rge C 4.0 u 125 ard S 100 rw o 2.0 F k Ambient Temperature, T a A 75 P.C.B. Mounting Pe 0.375" (9.5 mm) Lead Length 1.0 Cycle 0 50 0 50 100 150 1 10 100 Temperature (°C) Number of Cycles at 60 Hz Fig. 1 - Derating Curve Output Rectified Current Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Per Diode Revision: 08-Jul-13
2
Document Number: 88613 For technical questions within your region: [email protected], [email protected], [email protected] THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
