Источники питания Keen Side
Datasheet ADIS16334 (Analog Devices) - 9
ОписаниеLow Profile, Six Degrees of Freedom Inertial Sensor
Страниц / Страница21 / 9 — ADIS16334. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. °/sec). 0.1. …
ВерсияD
Формат / Размер файлаPDF / 496 Кб
ADIS16334. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. °/sec). 0.1. ANCE. ARI. µ +. AN V. 0.01. AL T. µ –. 0.001. 100. 1000 2000. TAU (sec)
ADIS16334 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS °/sec) 0.1 ANCE ARI µ + AN V 0.01 AL T µ – 0.001 100 1000 2000 TAU (sec)
Набор разработчика, ANALOG DEVICES ADIS16334BMLZ MEMS Module, Tri-Axis Gyroscope, Tri-Axis Accelerometer, 4.75V, 5.25V, Module, 20Pins
ADIS16334BMLZ
1 909 ₽
ЧипСити
ADIS16334BMLZ
44 452 ₽
ADIS16334BMLZ
46 773 ₽
T-electron
ADIS16334BMLZ
3 645 490 ₽
ADIS16334 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 1 10 ) °/sec) mg ( ( 0.1 1 ANCE ANCE ARI ARI µ + AN V µ + AN V L L 0.01 AL 0.1 AL T T O O RO RO µ µ µ – µ – 0.001 0.01 0.1 1 10 100 1000 2000
023
024
TAU (sec) T
09362-
AU (sec)
09362- Figure 7. Gyroscope Allan Variance Figure 8. Accelerometer Allan Variance Rev. B | Page 8 of 20 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Gyroscopes Accelerometers Data Sampling and Processing Calibration User Interface SPI Interface Basic Operation Reading Sensor Data Burst Read Function Memory Map Output Data Registers Gyroscopes Accelerometers Internal Temperature Measurements Device Configuration Dual Memory Structure Digital Processing Configuration Sample Rate Input Clock Configuration Digital Filtering Dynamic Range Optimizing Accuracy Automatic Bias Correction Manual Bias Correction Restoring Factory Calibration Point-of-Percussion/Linear-g Compensation System Tools Global Commands General-Purpose I/O Data Ready I/O Indicator Self-Test Memory Test Status Device Identification Flash Memory Management Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example Applications Information ADIS16334/PCBZ Installation Mounting Approaches Outline Dimensions Ordering Guide
