Datasheet LTC5596 (Analog Devices) - 2
Описание100MHz to 40GHz Linear-in-dB RMS Power Detector with 35dB Dynamic Range
Страниц / Страница22 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion …
Формат / Размер файлаPDF / 2.4 Мб
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion http://www.linear.com/product/LTC5596#orderinfo
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion http://www.linear.com/product/LTC5596#orderinfo
22 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ детекторы
727GS
LTC5596HDC#TRPBF
от 575 ₽
LTC5596HDC#TRPBF
4 109 ₽
LTC5596HDC#TRMPBF
от 4 636 ₽
Элитан
LTC5596HDC
13 088 ₽
LTC5596
Supply Voltage (VCC) ...3.8V TOP VIEW RFIN Input Signal Power - Average ...15dBm VCC 1 8 EN RFIN Input Signal Power - Peak (Note 2) ..20dBm OUT 2 7 GND 9 DC Voltage at RFIN ... –0.3V to 1V FLTR 3 6 RFIN DC Voltage at FLTR ... –0.3V to 0.4V GND 4 5 GND DC Voltage at EN ... –0.3V to 3.8V TJMAX .. 150°C DC PACKAGE Case Operating Temperature Range (TC): 8-LEAD (2mm × 2mm) PLASTIC DFN T I-Grade (Note 3) ... –40°C to 105°C JMAX = 150°C, θJC = 25°C/W EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB H-Grade (Note 4) ... –40°C to 125°C Storage Temperature Range .. –65°C to 150°C
orDer inForMaTion http://www.linear.com/product/LTC5596#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC5596IDC#PBF LTC5596IDC#TRPBF LGNN 8-Lead 2mm × 2mm Plastic DFN –40°C to 105°C LTC5596HDC#PBF LTC5596HDC#TRPBF LGNN 8-Lead 2mm × 2mm Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
elecTrical characTerisTics The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TC = 25°C. VCC = 3.3V, EN = 3.3V. CW, 50Ω source at RFIN, fRF = 2140MHz, test circuit is shown in Figure 1. (Note 2). I-GRADE (NOTE 3) H-GRADE (NOTE 4) PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS RF Input
Input Frequency Range 0.1 to 40 0.1 to 40 GHz Input Impedance 52||50 52||50 Ω||fF
Detector Response (RFIN to OUT)
RF Input Power Range, TC = 25°C fRF = 50MHz –33.2 to 6.3 –33.2 to 6.3 dBm ±1dB LOG-Linearity Error (Note 5, 6) fRF = 100MHz –37.1 to 5.8 –37.1 to 5.8 dBm fRF = 500MHz –40.8 to 3.3 –40.8 to 3.3 dBm fRF = 2.14GHz –39.1 to 4.2 –39.1 to 4.2 dBm fRF = 5.8GHz –39.7 to 3.7 –39.7 to 3.7 dBm fRF = 7.6GHz –38.9 to 4.3 –38.9 to 4.3 dBm fRF = 10GHz –39.0 to 4.2 –39.0 to 4.2 dBm fRF = 12GHz –38.5 to 4.5 –38.5 to 4.5 dBm fRF = 15GHz –37.5 to 5.5 –37.5 to 5.5 dBm fRF = 18GHz –38.4 to 4.6 –38.4 to 4.6 dBm fRF = 24GHz –39.3 to 0.2 –39.3 to 0.2 dBm 5596f 2 For more information www.linear.com/LTC5596 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Test Circuit Applications Information Package Description Typical Application Related Parts
