Источники питания Keen Side
Datasheet LTC5536 (Analog Devices) - 7
Описание600MHz to 7GHz Precision RF Detector with Fast Comparator Output
Страниц / Страница12 / 7 — PI FU CTIO S. RFIN (Pin 1):. LEN (Pin 4):. OUT (Pin 5):. VCC (Pin 6):. …
Формат / Размер файлаPDF / 169 Кб
PI FU CTIO S. RFIN (Pin 1):. LEN (Pin 4):. OUT (Pin 5):. VCC (Pin 6):. GND (Pin 2):. VM (Pin 3):. BLOCK DIAGRA
PI FU CTIO S RFIN (Pin 1): LEN (Pin 4): OUT (Pin 5): VCC (Pin 6): GND (Pin 2): VM (Pin 3): BLOCK DIAGRA
18 предложений от 13 поставщиков
, 600MHz to 7GHz Precision RF Detector with Fast Comparator Output
ЧипСити
LTC5536ES6#TRPBF
212 ₽
LTC5536ES6#TRPBF
329 ₽
LTC5536ES6#TRPBF
628 ₽
LTC5536ES6#TRPBF
LTC5536
U U U PI FU CTIO S RFIN (Pin 1):
RF Input Voltage. Referenced to VCC. A
LEN (Pin 4):
Latch Enable Input. Output is latched when coupling capacitor must be used to connect to the RF LEN is high and transparent when LEN is low. signal source. The frequency range is 600MHz to 7GHz.
V
This pin has an internal 500Ω termination, an internal
OUT (Pin 5):
Comparator Output. Schottky diode detector and a peak detector capacitor.
VCC (Pin 6):
Power Supply Voltage, 2.7V to 5.5V. V
GND (Pin 2):
Ground. CC should be bypassed appropriately with ceramic capacitors.
VM (Pin 3):
Comparator Negative Input. Apply reference voltage to this pin.
W BLOCK DIAGRA
RFSOURCE 12pF TO 200pF (DEPENDING ON VCC APPLICATION) 6 + COMP 5 VOUT – 500Ω 1 RFIN 3 VM 500Ω VP BIAS 7.5k 15pF + 100mV RF DET DC BIAS 7.5k – 4 LEN 50µA 50µA 10k 110k GND 2 5536 BD 5536f 7
