Клеммники KEEN SIDE
Datasheet LT5538 (Analog Devices) - 8
Описание40MHz to 3.8GHz RF Power Detector with 75dB Dynamic Range
Страниц / Страница12 / 8 — APPLICATIONS INFORMATION. Table 1. RF Input Impedance. FREQUENCY. RF …
Формат / Размер файлаPDF / 241 Кб
APPLICATIONS INFORMATION. Table 1. RF Input Impedance. FREQUENCY. RF INPUT. S11. (MHz). IMPEDANCE (Ω). MAG. ANGLE(°)
APPLICATIONS INFORMATION Table 1 RF Input Impedance FREQUENCY RF INPUT S11 (MHz) IMPEDANCE (Ω) MAG ANGLE(°)
34 предложений от 19 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ детекторы
ЧипСити
LT5538IDD#TRPBF
216 ₽
Рутоника
LT5538IDD#PBF
487 ₽
LT5538IDD#PBF
550 ₽
LT5538IDD#PBF
829 ₽
LT5538
The LT5538 is a 40MHz to 3.8 GHz logarithmic RF power matching elements are needed for a proper impedance detector. It consists of cascaded limiting amplifi ers and matching to a 50Ω source as shown in Figure 2. Refer to RF detectors. The output currents from every RF detector Figure 6 for the circuit schematic of the input matching are combined and low-pass fi ltered before applied to the network. The input impedance vs frequency of the RF input output buffer amplifi er. As a result, the fi nal DC output port IN+ is detailed in Table 1. voltage approximates the logarithm of the amplitude of the
input signal. The LT5538 is able to accurately measure an
RF signal over a 70dB dynamic range (–68dBm to 2dBm
at 2.1GHz) with 50Ω single-ended input impedance. The slope of linear to log transfer function is about 17.7mV/dB 40 47.3 + j129.7 0.800 38.5 at 2.1GHz. Within the linear dynamic range, very stable 100 246.6 + j210.7 0.790 11.5 output is achieved over the full temperature range from 200 408.7 – j37.8 0.785 –1.5 –40°C to 85°C and over the full operating frequency 400 192.9 – j190.9 0.772 –14.9 range from 40MHz to 3.8GHz. The absolute variation over 600 105.6 – j158.4 0.756 –25.3 temperature is typically within ±1dB over 65dB dynamic 800 69.3 – j127.4 0.737 –34.4 range at 2.1GHz. 1000 51.8 – j106.2 0.720 –42.7 1200 41.5 – j90.9 0.707 –50.6 1400 34.2 – j78.7 0.697 –58.2
RF INPUT
1600 29.2 – j60.0 0.687 –65.6 The simplifi ed schematic of the input circuit is shown in 1800 25.4 – j60.7 0.678 –73.1 Figure 1. The IN+ and IN– pins are internally biased to 2000 22.6 – j53.8 0.669 –80.4 VCC –0.5V. The IN– pin is internally coupled to ground via 2200 20.5 – j47.7 0.659 –87.7 20pF capacitor. An external capacitor of 1nF is needed to 2400 18.9 – j42.4 0.649 –94.6 connect this pin to ground for low frequency operation. 2600 17.9 – j37.6 0.638 –101.5 The impedance between IN+ and IN– is about 394Ω. The 2800 17.1 – j33.4 0.627 –108.2 RF input pin IN+ should be DC blocked when connected 3000 16.4 – j29.5 0.615 –114.7 to ground or other matching components. A 56Ω resistor 3200 16.1 – j26.0 0.602 –121.0 (R1) connected to ground will provide better than 10dB 3400 15.9 – j22.8 0.589 –127.0 input return loss over the operating frequency range up 3600 15.9 – j20.0 0.574 –132.8 to 1.5GHz. At higher operating frequency, additional LC 3800 15.9 – j17.5 0.560 –137.9 0 VCC –5 5.3k 5.3k –10 IN+ –15 394 IN– –20 INPUT RETURN LOSS (dB) W/O L1 AND C8 20p –25 + L1 = 1.5nH, C8 = 1pF C4, C11 = 12pF, C8 = 0.7pF – –30 0 0.4 0.8 1.2 1.6 2 2.4 2.8 3.2 3.6 4.0 5538 F01 FREQUENCY (GHz) 5538 F02
Figure 1. Simplifi ed Schematic of the Input Circuit Figure 2. Input Return Loss with Additional LC Matching Network
5538f 8
