Datasheet OP27 (Analog Devices) - 10
ОписаниеLow Noise, Precision Operational Amplifier
Страниц / Страница13 / 10 — STANDARD. 5962-94680. MICROCIRCUIT DRAWING
Формат / Размер файлаPDF / 113 Кб
STANDARD 5962-94680 MICROCIRCUIT DRAWING
59 предложений от 27 поставщиков
Усилители.Тип: Прецизионный операционный усилитель серии OP27Количество: каналов - 1Вес брутто: 0.30Транспортная упаковка: размер/кол-во: 60*50*37/2500Напряжение питания: двуполярное ± 5; ± 9; ±...
Триема
OP27GSZ-REEL
122 ₽
Зенер
Россия и страны ТС
OP27GSZ-REEL7
от 167 ₽
ИМЭК
Россия и страны ТС
OP27GSZ-REEL7 SOIC-8
172 ₽
ЭИК
OP27GSZ-REEL
от 464 ₽
TABLE IIA. Electrical test requirements. Test requirements Subgroups Subgroups (in accordance with (in accordance with MIL-STD-883, MIL-PRF-38535, table III) method 5005, table I) Device Device Device class M class Q class V Interim electrical 1 1 1 parameters (see 4.2) Final electrical 1,2,3,4 1/ 1,2,3,4 1/ 1,2,3,4 1/ 2/ parameters (see 4.2) Group A test 1,2,3,4 1,2,3,4 1,2,3,4 requirements (see 4.4) Group C end-point electrical 1 1 1 2/ parameters (see 4.4) Group D end-point electrical 1 1 1 parameters (see 4.4) Group E end-point electrical --- --- 1,4 parameters (see 4.4) 1/ PDA applies to subgroup 1. 2/ Delta limits as specified in table IIB shall be required where specified, and the delta limits shall be completed with reference to the zero hour electrical parameters (see table I). TABLE IIB. Burn-in and operating life test delta parameters. TA = +25C. 1/ 2/ Parameter Device type Limit Delta Min Max VIO 02, 03 -135 +135 75 V IIB 02, 03 -70 +70 10 nA 1/ Deltas are performed at room temperature. 2/ 240 hour burn-in and 1,000 hour operating group C life test. 4.4 Conformance inspection. Technology conformance inspection for classes Q and V shall be in accordance with MIL-PRF-38535 including groups A, B, C, D, and E inspections, and as specified herein. Quality conformance inspection for device class M shall be in accordance with MIL-PRF-38535, appendix A and as specified herein. Inspections to be performed for device class M shall be those specified in method 5005 of MIL-STD-883 and herein for groups A, B, C, D, and E inspections (see 4.4.1 through 4.4.4). 4.4.1 Group A inspection. a. Tests shall be as specified in table II herein. b. Subgroups 5, 6, 7, 8, 9, 10, and 11 in table I, method 5005 of MIL-STD-883 shall be omitted. 4.4.2 Group C inspection. The group C inspection end-point electrical parameters shall be as specified in table IIA herein.
STANDARD
SIZE
5962-94680 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 10 DSCC FORM 2234 APR 97
