Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet AD8361 (Analog Devices) - 7
ОписаниеLF to 2.5 GHz TruPwr™ Detector
Страниц / Страница23 / 7 — AD8361. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2.8. 3.0. 2.6. …
ВерсияF
Формат / Размер файлаPDF / 611 Кб
AD8361. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 2.8. 3.0. 2.6. 900MHz. 2.5. 2.4. 2.0. 2.2. 100MHz. 1900MHz. 1.5. 1.0. 1.8. 1.6. 0.5. 2.5GHz. 1.4. 1.2
AD8361 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 2.8 3.0 2.6 900MHz 2.5 2.4 2.0 2.2 100MHz 1900MHz 1.5 1.0 1.8 1.6 0.5 2.5GHz 1.4 1.2
11 предложений от 10 поставщиков
RF Detector IC Cellular, CDMA, W-CDMA 100MHz ~ 2.5GHz 0 ~ 700mV ±0.25dB 8-TSSOP, 8-MSOP (0.118, 3mm Width)
ЧипСити
AD8361ARM-REEL7
463 ₽
LIXINC Electronics
AD8361ARM-REEL7
от 755 ₽
T-electron
AD8361ARMREEL7
57 025 ₽
ЗУМ-СМД
AD8361ARM-REEL7
AD8361 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 2.8 3.0 2.6 900MHz 2.5 2.4 2.0 2.2 100MHz 1900MHz 1.5 2.0 1.0 1.8 1.6 0.5 2.5GHz 1.4 0 1.2 –0.5 OUTPUT (V) ERROR (dB) 1.0 –1.0 0.8 MEAN
3 SIGMA –1.5 0.6 –2.0 0.4 0.2 –2.5 0.0 –3.0 0 0.1 0.2 0.3 0.4 0.5 0.01 0.02 0.1 0.4 INPUT (V rms)
01088-C-006
(–21dBm) (–7dBm) (+5dBm) INPUT (V rms)
01088-C-009 Figure 6. Output vs. Input Level, Frequencies 100 MHz, 900 MHz, Figure 9. Error from Linear Reference vs. Input Level, 3 Sigma to Either Side of 1900 MHz, and 2500 MHz, Supply 2.7 V, Ground Reference Mode, MSOP Mean, Sine Wave, Supply 3.0 V, Frequency 900 MHz
5.5 5.5V 3.0 5.0 2.5 4.5 2.0 5.0V 4.0 1.5 3.0V 1.0 3.5 0.5 3.0 0 2.5 OUTPUT (V) –0.5 2.0 ERROR (dB) 2.7V –1.0 1.5 MEAN
3 SIGMA –1.5 1.0 –2.0 0.5 –2.5 0.0 –3.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.01 0.02 0.1 0.6 INPUT (V rms)
01088-C-007
(–21dBm) (–7dBm) (+8.6dBm) INPUT (V rms)
01088-C-010 Figure 7. Output vs. Input Level, Figure 10. Error from Linear Reference vs. Input Level, 3 Sigma to Either Side Supply 2.7 V, 3.0 V, 5.0 V, and 5.5 V, Frequency 900 MHz of Mean, Sine Wave, Supply 5.0 V, Frequency 900 MHz
5.0 3.0 CW IS95 2.5 4.5 REVERSE LINK 2.0 4.0 1.5 3.5 IS95 1.0 CW REVERSE LINK 3.0 0.5 2.5 0.0 WCDMA 2.0 –0.5 4-CHANNEL OUTPUT (V) 4- AND 15-CHANNEL ERROR (dB) –1.0 1.5 –1.5 15-CHANNEL 1.0 –2.0 0.5 –2.5 0.0 –3.0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.01 0.02 0.1 0.2 0.6 1.0 INPUT (V rms)
01088-C-008
INPUT (V rms)
01088-C-011 Figure 8. Output vs. Input Level with Figure 11. Error from CW Linear Reference vs. Input with Different Different Waveforms Sine Wave (CW), IS95 Reverse Link, Waveforms Sine Wave (CW), IS95 Reverse Link, W-CDMA 4-Channel and W-CDMA 4-Channel and W-CDMA 15-Channel, Supply 5.0 V W-CDMA 15-Channel, Supply 3.0 V, Frequency 900 MHz Rev. F | Page 6 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION Filtering Offset APPLICATION INFORMATION Basic Connections Output Swing Dynamic Range Input Coupling and Matching Input Coupling Using a Series Resistor Selecting the Filter Capacitor Operation at Low Frequencies Power Consumption, Enable and Power-On Volts to dBm Conversion Output Drive Capability and Buffering OUTPUT REFERENCE TEMPERATURE DRIFT COMPENSATION Extended Frequency Characterization EVALUATION BOARD CHARACTERIZATION SETUPS Equipment Analysis OUTLINE DIMENSIONS ORDERING GUIDE
