Datasheet ADL5566 (Analog Devices) - 9
Описание4.5 GHz Ultrahigh Dynamic Range, Dual Differential Amplifier
Страниц / Страница25 / 9 — ADL5566. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.7. 0.07. …
ВерсияA
Формат / Размер файлаPDF / 838 Кб
ADL5566. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.7. 0.07. 3.3V, 25°C. SDD21 PHASE. 5V, 25°C. SDD21 MAG. 0.6. 0.06. 0.5. 0.05. rees)
ADL5566 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 0.7 0.07 3.3V, 25°C SDD21 PHASE 5V, 25°C SDD21 MAG 0.6 0.06 0.5 0.05 rees)
37 предложений от 18 поставщиков
727GS
ADL5566ACPZ-R7
от 153 ₽
ADL5566ACPZ-R7
от 320 ₽
IC Home
ADL5566ACPZ-R7
1 362 ₽
ADL5566ACPZ-R7
1 830 ₽
VS = 3.3 V, VCM = 1.65 V, RL = 200 Ω differential, AV = 16 dB, CL = 1 pF differential, f = 100 MHz, TA = 25°C, parameters specified as ac-coupled differential input and differential output, unless otherwise noted.
25 0.7 0.07 3.3V, 25°C SDD21 PHASE 5V, 25°C SDD21 MAG 20 0.6 0.06 15 0.5 0.05 rees) B) 10 (d B) Deg ( 0.4 R d 0.04 ( R 5 IN RRO RRO GA 0.3 0.03 E N E 0 E AI G HAS 0.2 0.02 –5 P –10 0.1 0.01 –15 0 0 10M 100M 1G
003
10 100 1000
106
FREQUENCY (Hz)
10916-
FREQUENCY (MHz)
10916- Figure 3. Gain vs. Frequency Response for 200 Ω Differential Load, Figure 6. Channel-to-Channel Gain Error and Phase Error vs. Frequency VPOS = 3.3 V and VPOS = 5 V, 25°C
25 25 3.3V, –40°C 3.3V, +25°C 20 3.3V, +85°C 3.3V, +105°C 20 15 10 B) 15 Bm) (d d 5 IN B ( GA 1d P 0 10 O 5V, +25°C 5V, –40°C –5 5V, +85°C 5 5V, +105°C 3.3V, +25°C –10 3.3V, –40°C 3.3V, +85°C 3.3V, +105°C –15 0 10M 100M 1G
004
0 50 100 150 200 250
006
FREQUENCY (Hz)
10916-
FREQUENCY (MHz)
10916- Figure 4. Gain vs. Frequency Response for 200 Ω Differential Load, Figure 7. OP1dB vs. Frequency for 200 Ω Differential Load, Four Four Temperatures, VPOS = 3.3 V Temperatures, VPOS = 3.3 V, VPOS = 5 V
25 10.0 5V, –40°C 3.3V SUPPLY 5V, +25°C 9.5 5V SUPPLY 20 5V, +85°C 5V, +105°C 9.0 8.5 15 8.0 ) 10 dB 7.5 ( B) E 7.0 R (d 5 IN 6.5 FIGU GA E 6.0 0 5.5 OIS N 5.0 –5 4.5 –10 4.0 3.5 –15 3.0 10M 100M 1G
005
10M 100M 1G
007
FREQUENCY (Hz)
10916-
FREQUENCY (Hz)
10916- Figure 5. Gain vs. Frequency Response for 200 Ω Differential Load, Figure 8. Noise Figure vs. Frequency at VPOS = 3.3 V, VPOS = 5 V, 25°C Four Temperatures, VPOS = 5 V Rev. A | Page 8 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Applications Information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing DC-Coupled Receiver Application Layout Considerations Soldering Information and Recommended Land Pattern Evaluation Board Outline Dimensions Ordering Guide
