Datasheet ADL5205 (Analog Devices) - 10
ОписаниеDual, 35 dB Range, 1 dB Step Size DGA
Страниц / Страница32 / 10 — Data Sheet. ADL5205. TYPICAL PERFORMANCE CHARACTERISTICS. 185. 184. …
Data Sheet. ADL5205. TYPICAL PERFORMANCE CHARACTERISTICS. 185. 184. 3.45V. 183. 3.3V. 182. 3.15V. 181. 5.25V. 180. 5.0V. A) 179. 4.75V. (m 178. N 177. 176
Data Sheet ADL5205 TYPICAL PERFORMANCE CHARACTERISTICS 185 184 3.45V 183 3.3V 182 3.15V 181 5.25V 180 5.0V A) 179 4.75V (m 178 N 177 176
30 предложений от 13 поставщиков
727GS
ADL5205ACPZ-R7
от 320 ₽
ADL5205ACPZ-R7
от 1 272 ₽
ADL5205ACPZ-R7
2 512 ₽
T-electron
ADL5205ACPZR7
121 765 ₽
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
Supply voltage (VPOS) = 3.3 V or 5 V, TA = 25°C, ZLOAD = 200 Ω, maximum gain (gain code = 000000), 2 V p-p composite differential output for intermodulation distortion (IMD) and OIP3, 2 V p-p differential output for second harmonic distortion (HD2) and third harmonic distortion (HD3), VCMA = VCMB = VPOS/2, unless otherwise noted.
185 60 184 3.45V 183 3.3V 182 3.15V 50 181 5.25V 180 5.0V A) 179 4.75V (m 178 40 T ) N 177 E m 176 B d 175 30 3 ( 174 CURR 173 LY OIP P 172 20 UP 171 S 5V, 26dB 170 5V, 14dB 169 10 5V, 6dB 168 3.3V, 26dB 167 3.3V, 14dB 166 3.3V, 6dB 165 0
09
–40 25 85
06
0 100 200 300 400 500
0 0 88-
TEMPERATURE (°C) FREQUENCY (MHz)
3488- 1 134 Figure 6. Supply Current vs. Temperature, PM = 0 Figure 9. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS at Three Gain Codes, High Performance Mode
145 60 3.45V 143 3.3V 3.15V 50 141 5.25V ) 5.0V A 139 4.75V m ( 40 NT 137 ) m B d 135 30 3 ( CURRE 133 LY OIP P 20 UP 131 S 5V, +85°C 5V, +25°C 129 10 5V, –40°C 3.3V, +85°C 127 3.3V, +25°C 3.3V, –40°C 125 0
10
–40 25 85
07
0 0 8-
3488- 348 1 1 Figure 7. Supply Current vs. Temperature, PM = 1 Figure 10. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS for Three Temperatures at Maximum Gain, High Performance Mode
30 60 –40°C +25°C 25 +85°C 50 20 15 40 ) ) m 10 B (dB d 30 IN 3 ( 5 GA OIP 0 20 5V, 26dB –5 5V, 14dB 10 5V, 6dB 3.3V, 26dB –10 3.3V, 14dB 3.3V, 6dB –15 0
1 8 1
0 5 10 15 20 25 30 35 40 0 100 200 300 400 500
0 -00 8
GAIN CODE
48
FREQUENCY (MHz)
3488- 1 13 Figure 8. Gain vs. Gain Code over Temperature at 200 MHz Figure 11. Output Third-Order Intercept (OIP3) vs. Frequency over VPOS at Three Gain Codes, Low Power Mode Rev. 0 | Page 9 of 31 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE JUNCTION TO BOARD THERMAL IMPEDANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC STRUCTURE CONTROL/LOGIC CIRCUITRY COMMON-MODE VOLTAGE APPLICATIONS INFORMATION BASIC CONNECTIONS DIGITAL INTERFACE OVERVIEW Parallel Digital Interface Serial Peripheral Interface (SPI) Up/Down Interface SPI READ ADC INTERFACING NOISE FIGURE vs. GAIN SETTING EVALUATION BOARD OVERVIEW POWER SUPPLY INTERFACE SIGNAL INPUTS AND OUTPUTS MANUAL CONTROLS Mode Switches Channel Control Switches PARALLEL INTERFACE SERIAL INTERFACE STANDARD DEVELOPMENT PLATFORM (SDP) INTERFACE EVALUATION BOARD CONTROL SOFTWARE COMMAND LINE CONTROL PROGRAM GRAPHICAL USER INTERFACE (GUI) PROGRAM EVALUATION BOARD SCHEMATICS AND LAYOUT BILL OF MATERIALS OUTLINE DIMENSIONS ORDERING GUIDE
