Клеммные колодки Keen Side
Datasheet AD7450 (Analog Devices) - 7
ОписаниеDifferential Input, 1 MSPS, 12-BIT SAR ADC
Страниц / Страница23 / 7 — AD7450. PIN CONFIGURATION. REF. SCLK. IN+. TOP VIEW. 3 (Not to Scale) 6. …
ВерсияA
Формат / Размер файлаPDF / 506 Кб
AD7450. PIN CONFIGURATION. REF. SCLK. IN+. TOP VIEW. 3 (Not to Scale) 6. IN–. SDATA. GND 4. PIN FUNCTION DESCRIPTION. Pin Number. Mnemonic
AD7450 PIN CONFIGURATION REF SCLK IN+ TOP VIEW 3 (Not to Scale) 6 IN– SDATA GND 4 PIN FUNCTION DESCRIPTION Pin Number Mnemonic
26 предложений от 13 поставщиков
12-разрядный АЦП с дифференциальным входом, быстродействие 1 MSPS
AD7450BRZ
788 ₽
AD7450BRZ
864 ₽
ЧипСити
AD7450BRZ
927 ₽
Зенер
Россия и страны ТС
AD7450BRZ
от 2 191 ₽
AD7450 PIN CONFIGURATION 1 8 V V REF DD V 2 AD7450 7 SCLK IN+ TOP VIEW V 3 (Not to Scale) 6 IN– SDATA GND 4 5 CS PIN FUNCTION DESCRIPTION Pin Number Mnemonic Function
1 VREF Reference Input for the AD7450. An external reference must be applied to this input. For a 5 V power supply, the reference is 2.5 V (± 1%), and for a 3 V power supply, the reference is 1.25 V (± 1%) for specified performance. This pin should be decoupled to GND with a capacitor of at least 0.1 µF. See the References section for more details. 2 VIN+ Positive Terminal for Differential Analog Input 3 VIN– Negative Terminal for Differential Analog Input 4 GND Analog Ground. Ground reference point for all circuitry on the AD7450. All analog input signals and any external reference signal should be referred to this GND voltage. 5 CS Chip Select. Active low logic input. This input provides the dual function of initiating a conversion on the AD7450 and framing the serial data transfer. 6 SDATA Serial Data. Logic output. The conversion result from the AD7450 is provided on this output as a serial data stream. The bits are clocked out on the falling edge of the SCLK input. The data stream consists of four leading zeros followed by the 12 bits of conversion data that is provided MSB first. The output coding is two’s complement. 7 SCLK Serial Clock. Logic input. SCLK provides the serial clock for accessing data from the part. This clock input is also used as the clock source for the AD7450’s conversion process. 8 VDD Power Supply Input. VDD is 3 V (± 10%) or 5 V (± 5%). This supply should be decoupled to GND with a 0.1 µF capacitor and a 10 µF tantalum capacitor. –6– Rev. A
