Datasheet AD7984 (Analog Devices) - 7
Описание18-Bit, 1.33 MSPS PulSAR 10.5 mW ADC in MSOP/QFN
Страниц / Страница25 / 7 — AD7984. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. …
ВерсияB
Формат / Размер файлаPDF / 667 Кб
AD7984. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. ESD CAUTION
AD7984 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
14 предложений от 9 поставщиков
18Bit, 1.33MSPS PulSAR 10.5mW ADC in MSOP/QFN
LIXINC Electronics
AD7984BRMZ-RL7
от 254 ₽
ЧипСити
AD7984BRMZ-RL7
2 620 ₽
Akcel
AD7984BRMZ-RL7
от 3 250 ₽
Allelco
AD7984BRMZ-RL7
link to page 15
AD7984 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any Analog Inputs other conditions above those indicated in the operational IN+, IN− to GND1 −0.3 V to VREF + 0.3 V or ±130 mA section of this specification is not implied. Exposure to absolute Supply Voltage maximum rating conditions for extended periods may affect REF, VIO to GND −0.3 V to +6.0 V device reliability. VDD to GND −0.3 V to +3.0 V VDD to VIO +3 V to −6 V
ESD CAUTION
Digital Inputs to GND −0.3 V to VIO + 0.3 V Digital Outputs to GND −0.3 V to VIO + 0.3 V Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θJA Thermal Impedance 10-Lead MSOP 200°C/W 10-Lead LFCSP 48.7°C/W θJC Thermal Impedance 10-Lead MSOP 44°C/W 10-Lead LFCSP 2.96°C/W Lead Temperatures Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C 1 See the Analog Inputs section for an explanation of IN+ and IN−. Rev. B | Page 6 of 24 Document Outline FEATURES APPLICATIONS APPLICATION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION Transfer Functions TYPICAL CONNECTION DIAGRAM ANALOG INPUTS DRIVER AMPLIFIER CHOICE SINGLE-TO-DIFFERENTIAL DRIVER VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE MODE, 3-CS WIRE WITHOUT BUSY INDICATOR CS MODE, 3-WIRE WITH BUSY INDICATOR CS MODE, 4-WIRE WITHOUT BUSY INDICATOR CS MODE, 4-WIRE WITH BUSY INDICATOR CHAIN MODE WITHOUT BUSY INDICATOR CHAIN MODE WITH BUSY INDICATOR APPLICATION HINTS LAYOUT EVALUATING THE AD7984 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
