Клеммные колодки Keen Side
Datasheet AD7609 (Analog Devices) - 7
Описание8-Channel Differential DAS with 18-Bit, Bipolar, Simultaneous Sampling ADC
Страниц / Страница37 / 7 — AD7609. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияC
Формат / Размер файлаPDF / 893 Кб
AD7609. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7609 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
31 предложений от 21 поставщиков
Микросхема Преобразователь AD, ANALOG DEVICES AD7609BSTZ Analog to Digital Converter, 18Bit, 250KSPS, Single, 4.75V, 5.25V, LQFP
727GS
AD7609BSTZ
от 353 ₽
AD7609BSTZ
от 1 157 ₽
Зенер
Россия и страны ТС
AD7609BSTZ
от 3 337 ₽
AD7609BSTZ
link to page 20 link to page 22 link to page 7
Power Dissipation Normal Mode (Static) 80 115.5 mW Normal Mode (Operational)8 fSAMPLE = 200 kSPS 100 157 mW Standby Mode 25 42 mW Shutdown Mode 10 60.5 µW 1 Temperature range for B version is −40°C to +85°C. 2 See the Terminology section. 3 This specification applies when reading during a conversion or after a conversion. If reading during a conversion in parallel and serial modes with VDRIVE = 5 V, SNR typically reduces by 1.5 dB and THD by 3 dB. 4 LSB means least significant bit. With ±5 V input range, 1 LSB = 76.29 µV. With ±10 V input range, 1 LSB = 152.58 µV. 5 These specifications include the full temperature range variation and contribution from the internal reference buffer but do not include the error contribution from the external reference. 6 Bipolar zero code error is calculated with respect to the analog input voltage. See the Analog Input Clamp Protection section. 7 Sample tested during initial release to ensure compliance. 8 Operational power/current figure includes contribution when running in oversampling mode. Rev. B | Page 6 of 36 Document Outline Features Applications Companion Products Functional Block Diagram Table of Contents Revision History General Description Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Converter Details Analog Input Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter Track-and-Hold Amplifiers ADC Transfer Function Internal/External Reference External Reference Mode Internal Reference Mode Typical Connection Diagram Power-Down Modes Conversion Control Simultaneous Sampling on All Analog Input Channels Simultaneously Sampling Two Sets of Channels Digital Interface Parallel Interface (/PAR/SER SEL = 0) Serial Interface (/PAR/SER SEL = 1) Reading During Conversion Digital Filter Layout Guidelines Outline Dimensions Ordering Guide
