Datasheet AD7609 (Analog Devices) - 5
Описание8-Channel Differential DAS with 18-Bit, Bipolar, Simultaneous Sampling ADC
Страниц / Страница37 / 5 — AD7609. Data Sheet. SPECIFICATIONS. Table 2. Parameter. Test …
ВерсияC
Формат / Размер файлаPDF / 893 Кб
AD7609. Data Sheet. SPECIFICATIONS. Table 2. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7609 Data Sheet SPECIFICATIONS Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
32 предложений от 15 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
AD7609BSTZ-RL
от 1 157 ₽
AD7609BSTZ-RL
1 885 ₽
AD7609BSTZ-RL
3 468 ₽
TradeElectronics
AD7609BSTZ-RL
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
link to page 8 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
VREF = 2.5 V external/internal, AVCC = 4.75 V to 5.25 V, VDRIVE = 2.3 V to 5.25 V; fSAMPLE = 200 kSPS, TA = TMIN to TMAX, unless otherwise noted.1
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE fIN = 1 kHz sine wave unless otherwise noted Signal-to-Noise Ratio (SNR)2, 3 Oversampling by 16; ±10 V range; fIN = 160 Hz 98 101 dB Oversampling by 16; ±5 V range; fIN = 160 Hz 100 dB No oversampling; ±10 V range 90 91 dB No oversampling; ±5 V range 89.5 90.5 dB Signal-to-(Noise + Distortion) (SINAD)2 No oversampling; ±10 V range 89.5 91 dB No oversampling; ±5 V range 89 90 dB Dynamic Range No oversampling; ±10 V range 91.5 dB No oversampling; ±5 V range 90.5 dB Total Harmonic Distortion (THD)2, 3 No oversampling; ±10 V range −107 −97 dB No oversampling; ±5 V range −110 −96 dB Peak Harmonic or Spurious Noise (SFDR)2 −108 dB Intermodulation Distortion (IMD)2 fa = 1 kHz, fb = 1.1 kHz Second-Order Terms −110 dB Third-Order Terms −106 dB Channel-to-Channel Isolation2 fIN on unselected channels up to 160 kHz −95 dB ANALOG INPUT FILTER Full Power Bandwidth −3 dB, ±10 V range 32 kHz −3 dB, ±5 V range 23 kHz −0.1 dB, ±10 V range 13 kHz −0.1 dB, ±5 V range 10 kHz tGROUP DELAY ±10 V range 7.1 µs ±5 V range 10.2 µs DC ACCURACY Resolution No missing codes 18 Bits Differential Nonlinearity2 ±0.75 −0.99/+2 LSB4 Integral Nonlinearity2 ±3 ±7.5 LSB Total Unadjusted Error (TUE) ±10 V range ±10 LSB ±5 V range ±90 LSB Positive Full-Scale Error2, 5 External reference ±8 ±140 LSB Internal reference ±40 LSB Positive Full-Scale Error Drift External reference ±2 ppm/°C Internal reference ±7 ppm/°C Positive Full-Scale Error Matching2 ±10 V range 12 80 LSB ±5 V range 40 100 LSB Bipolar Zero Code Error2, 6 ±10 V range ±3 ±24 LSB ± 5 V range ±3 ±48 LSB Bipolar Zero Code Error Drift ±10 V range 10 µV/°C ± 5 V range 5 µV/°C Bipolar Zero Code Error Matching2 ±10 V range 2.7 30 LSB ±5 V range 13 65 LSB Negative Full-Scale Error2, 5 External reference ±8 ±140 LSB Internal reference ±40 LSB Negative Full-Scale Error Drift External reference ±4 ppm/°C Internal reference ±8 ppm/°C Negative Full-Scale Error Matching2 ±10 V range 12 80 LSB ±5 V range 40 100 LSB Rev. B | Page 4 of 36 Document Outline Features Applications Companion Products Functional Block Diagram Table of Contents Revision History General Description Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Converter Details Analog Input Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter Track-and-Hold Amplifiers ADC Transfer Function Internal/External Reference External Reference Mode Internal Reference Mode Typical Connection Diagram Power-Down Modes Conversion Control Simultaneous Sampling on All Analog Input Channels Simultaneously Sampling Two Sets of Channels Digital Interface Parallel Interface (/PAR/SER SEL = 0) Serial Interface (/PAR/SER SEL = 1) Reading During Conversion Digital Filter Layout Guidelines Outline Dimensions Ordering Guide
