Datasheet LT3063 (Analog Devices) - 4
Описание45V VIN, Micropower, Low Noise, 200mA LDO with Active Output Discharge
Страниц / Страница22 / 4 — ELECTRICAL CHARACTERISTICS Note 1:. Note 6:. Note 2:. Note 7:. Note 3:. …
Формат / Размер файлаPDF / 975 Кб
ELECTRICAL CHARACTERISTICS Note 1:. Note 6:. Note 2:. Note 7:. Note 3:. Note 8:. Note 9:. Note 10:. Note 11:. Note 12:. Note 4:. Note 5:
ELECTRICAL CHARACTERISTICS Note 1: Note 6: Note 2: Note 7: Note 3: Note 8: Note 9: Note 10: Note 11: Note 12: Note 4: Note 5:
17 предложений от 10 поставщиков
Стабилизатор с малым падением напряжения, фиксированный, 1.6В до 45В вход, 5В/200мА, 300мВ, MSOP-8
LT3063IMS8E-5#TRPBF
81 ₽
LT3063IMS8E-5#PBF
84 ₽
LT3063IMS8E-5#PBF
от 531 ₽
LT3063IMS8E-5#PBF
LT3063 Series
Note 6:
To satisfy minimum input voltage requirements, the LT3063 may cause permanent damage to the device. Exposure to any Absolute adjustable version is tested and specified for these conditions with an Maximum Rating condition for extended periods may affect device external resistor divider (bottom 60k, top 230k) for an output voltage of reliability and lifetime. 2.9V. The external resistor divider adds 10µA of DC load on the output.
Note 2:
Absolute maximum input to output differential voltage is not The external current is not factored into GND pin current. achievable with all combinations of rated IN pin and OUT pin voltages.
Note 7:
Dropout voltage is the minimum input-to-output voltage With the IN pin at 50V, the OUT pin may not be pulled below 0V. The total differential needed to maintain regulation at a specified output current. In measured voltage from IN to OUT must not exceed ±50V. dropout, the output voltage equals: (VIN – VDROPOUT).
Note 3:
The LT3063 is tested and specified under pulse load conditions
Note 8:
GND pin current is tested with VIN = VOUT(NOMINAL) + 0.6V and a such that TJ ≅ TA. The LT3063E regulators are 100% tested at TA = 25°C current source load. GND pin current will increase in dropout. See GND and performance is guaranteed from 0°C to 125°C. Performance at pin current curves in the Typical Performance Characteristics section. For –40°C to 125°C is assured by design, characterization and correlation fixed voltage options, an internal resistor divider will add 5μA to the GND with statistical process controls. The LT3063I regulators are guaranteed pin current. See the GND Pin Current curves in the Typical Performance over the full –40°C to 125°C operating junction temperature range. The Characteristics section. LT3063MP regulators are 100% tested over the –55°C to 150°C operating
Note 9:
ADJ pin bias current flows out of the ADJ pin. junction temperature. The LT3063H regulators are 100% tested at the
Note 10:
SHDN pin current flows into the SHDN pin. 150°C operating junction temperature. High junction temperatures degrade
Note 11:
To satisfy requirements for minimum input voltage, current limit operating lifetimes. Operating lifetime is derated at junction temperature is tested at V greater than 125°C. IN = VOUT(NOMINAL) + 1V or VIN = 2.1V, whichever is greater.
Note 12:
This IC includes thermal limit which protects the device during
Note 4:
The LT3063 adjustable version is tested and specified for these momentary overload conditions. Junction temperature exceeds 125°C conditions with the ADJ connected to the OUT pin. (E- and I-Grades) or 150°C (MP- and H-Grades) when thermal limit is
Note 5:
Maximum junction temperature limits operating conditions. The active. Continuous operation above the specified maximum junction regulated output voltage specification does not apply for all possible temperature may impair device reliability. combinations of input voltage and output current. Limit the output current range if operating at the maximum input voltage. Limit the input-to-output voltage differential if operating at maximum output current. Current limit foldback limits the maximum output current as a function of input-to- output voltage. See Current Limit vs VIN – VOUT in the Typical Performance Characteristics section. 3063fa 4 For more information www.linear.com/LT3063 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
