Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet LTC2283 (Analog Devices) - 3
ОписаниеDual 12-Bit, 125Msps Low Power 3V ADC
Страниц / Страница24 / 3 — The. CONVERTER CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 589 Кб
The. CONVERTER CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The CONVERTER CHARACTERISTICS denotes the specifi cations which apply over the full operating
Dual ADC Pipelined 125Msps 12-bit Parallel 64-Pin QFN EP T/R
LTC2283CUP#TRPBF
3 917 ₽
LTC2283CUP#TRPBF
4 600 ₽
HXD Co.
LTC2283CUP#TRPBF
LTC2283CUP#TRPBF
LTC2283
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Offset Matching ±2 mV Transition Noise SENSE = 1V 0.32 LSBRMS
ANALOG INPUT The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN –AIN ) 2.85V < VDD < 3.4V (Note 7) ● ±0.5V to ±1V V V + – IN,CM Analog Input Common Mode (AIN +AIN )/2 Differential Input Drive (Note 7) ● 1 1.5 1.9 V Single Ended Input Drive (Note 7) ● 0.5 1.5 2 V I + – IN Analog Input Leakage Current 0V < AIN , AIN < VDD ● –1 1 μA ISENSE SENSEA, SENSEB Input Leakage 0V < SENSEA, SENSEB < 1V ● –3 3 μA IMODE MODE Input Leakage Current 0V < MODE < VDD ● –3 3 μA tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Time Jitter 0.2 psRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB Full Power Bandwidth Figure 8 Test Circuit 640 MHz
DYNAMIC ACCURACY The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input 70.2 dB 30MHz Input 70.1 dB 70MHz Input ● 68 70 dB 140MHz Input 69.6 dB SFDR Spurious Free Dynamic Range 5MHz Input 88 dB 2nd or 3rd Harmonic 30MHz Input 85 dB 70MHz Input ● 70 82 dB 140MHz Input 78 dB SFDR Spurious Free Dynamic Range 5MHz Input 90 dB 4th Harmonic or Higher 30MHz Input 90 dB 70MHz Input ● 77 90 dB 140MHz Input 90 dB S/(N+D) Signal-to-Noise Plus Distortion Ratio 5MHz Input 69.8 dB 30MHz Input 69.7 dB 70MHz Input ● 67 69.6 dB 140MHz Input 69.5 dB IMD Intermodulation Distortion fIN = 40MHz, 41MHz 85 dB Crosstalk fIN = 100MHz –110 dB 2283fb 3
