Datasheet OP471 (Analog Devices) - 3
Описание | High Speed, Low Noise Quad Operational Amplifier |
Страниц / Страница | 17 / 3 — OP471–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (@ VS =. 15 V, TA = 25. … |
Версия | A |
Формат / Размер файла | PDF / 337 Кб |
Язык документа | английский |
OP471–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (@ VS =. 15 V, TA = 25. C, unless otherwise noted.). OP471E. OP471F. OP471G
18 предложений от 12 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные |
| OP471GS-REEL Analog Devices | 778 ₽ | |
| OP471GS-REEL Analog Devices | по запросу | |
OP471–SPECIFICATIONS ELECTRICAL CHARACTERISTICS (@ VS = 15 V, TA = 25 C, unless otherwise noted.) OP471E OP471F OP471G Parameter Symbol Conditions Min Typ Max Min Typ Max Min Typ Max Unit
Input Offset Voltage VOS 0.25 0.8 0.5 1.5 1.0 1.8 mV Input Offset Current IOS VCM = 0 V 4 10 7 20 12 30 nA Input Bias Current IB VCM = 0 V 7 25 15 50 25 60 nA Input Noise Voltage1 en p-p 0.1 Hz to 10 Hz 250 500 250 500 250 500 nV p–p Input Noise en fO = 10 Hz 9 16 9 16 9 16 nV/÷Hz Voltage Density2 fO = 100 Hz 7 12 7 12 7 12 nV/÷Hz fO = 1 kHz 6.5 11 6.5 11 6.5 11 nV/÷Hz Input Noise in fO = 10 Hz 1.7 1.7 1.7 pA÷Hz Current Density fO = 100 Hz 0.7 0.7 0 7 pA÷Hz fO = 1 kHz 0.4 0.4 0.4 pA÷Hz Large-Signal AVO V = ±10 V Voltage Gain RL = 10 kW 500 700 300 500 300 500 V/mV RL = 2 kW 350 550 175 275 175 275 V/mV Input Voltage Range3 IVR ±11 ±12 ±11 ±12 ±11 ±12 V Output Voltage Swing VO RL ≥ 2 kW ±12 ±13 ±12 ±13 ±12 ±13 V Common-Mode CMR VCM = ± 11 V 105 120 95 115 95 115 dB Rejection Power Supply PSRR VS = 4.5 V to 18 V 1 5.6 5.6 17.8 5.6 17.8 mV/V Rejection Ratio Slew Rate SR 6.5 8 6.5 8 6.5 8 V/ms Supply Current ISY No Load 9.2 11 9.2 11 9.2 11 mA (All Amplifiers) Gain Bandwidth GBW Av = 10 6.5 6.5 6.5 MHz Product Channel Separation1 CS VO = 20 V p-p 125 150 125 150 125 150 dB fO = 10 Hz Input Capacitance CIN 2.6 2.6 2.6 pF Input Resistance RIN 1.1 1.1 1.1 MW Differential-Mode Input Resistance RINCM 11 11 11 GW Common-Mode Settling Time tS AV = 1 To 0.1% 4.5 4.5 4.5 ms To 0.01 % 7.5 7.5 7.5 ms NOTES 1Guaranteed but not 100% tested. 2Sample tested. 3Guaranteed by CMR test. –2– REV. A
