Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet AD8044 (Analog Devices) - 6
ОписаниеQuad 150 MHz Rail-to-Rail Amplifier
Страниц / Страница18 / 6 — AD8044–SPECIFICATIONS (@ TA = +25. C, VS =. 5 V, RL = 2 k. to 0 V, unless …
ВерсияB
Формат / Размер файлаPDF / 322 Кб
AD8044–SPECIFICATIONS (@ TA = +25. C, VS =. 5 V, RL = 2 k. to 0 V, unless otherwise noted.). AD8044A. Parameter. Conditions. Min. Typ
AD8044–SPECIFICATIONS (@ TA = +25 C, VS = 5 V, RL = 2 k to 0 V, unless otherwise noted.) AD8044A Parameter Conditions Min Typ
C, VS =
5 V, RL = 2 k
to 0 V, unless otherwise noted.) AD8044A Parameter Conditions Min Typ Max Units
DYNAMIC PERFORMANCE –3 dB Small Signal Bandwidth, VO < 0.5 V p-p G = +1 85 160 MHz Bandwidth for 0.1 dB Flatness G = +2, RL = 150 W 15 MHz Slew Rate G = –1, VO = 8 V Step 150 190 V/ms Full Power Response VO = 2 V p-p 29 MHz Settling Time to 0.1% G = –1, VO = 2 V Step 30 ns Settling Time to 0.01% 40 ns NOISE/DISTORTION PERFORMANCE Total Harmonic Distortion fC = 5 MHz, VO = 2 V p-p, G = +2 –72 dB Input Voltage Noise f = 10 kHz 16 nV/÷Hz Input Current Noise f = 10 kHz 900 fA/÷Hz Differential Gain Error (NTSC) G = +2, RL = 150 W 0.06 % Differential Phase Error (NTSC) G = +2, RL = 150 W 0.15 Degrees Crosstalk f = 5 MHz, RL = 1 kW, G = +2 –60 dB DC PERFORMANCE Input Offset Voltage 1.4 6.5 mV TMIN–TMAX 9 mV Offset Drift 10 mV/∞C Input Bias Current 2 4.5 mA TMIN–TMAX 4.5 mA Input Offset Current 0.2 1.2 mA Open-Loop Gain RL = 1 kW 82 96 dB TMIN–TMAX 92 dB INPUT CHARACTERISTICS Input Resistance 225 kW Input Capacitance 1.6 pF Input Common-Mode Voltage Range –5.2 to 4 V Common-Mode Rejection Ratio VCM = –5 V to 3.5 V 76 90 dB OUTPUT CHARACTERISTICS Output Voltage Swing RL = 10 kW –4.97 to +4.97 V Output Voltage Swing: RL = 1 kW –4.6 to +4.6 –4.85 to +4.85 V Output Voltage Swing: RL = 150 W –4.0 to +3.8 –4.5 to +4.5 V Output Current TMIN–TMAX, VOUT = –4.5 V to +4.5 V 30 mA Short Circuit Current Sourcing 60 mA Sinking 100 mA Capacitive Load Drive G = +2 40 pF POWER SUPPLY Operating Range 3 12 V Quiescent Current 11.5 13.6 mA Power Supply Rejection Ratio VS = –5, +5 V, ± 1 V 70 80 dB OPERATING TEMPERATURE RANGE –40 +85 ∞C Specifications subject to change without notice. –4– REV. B Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Driving Capacitance Loads APPLICATIONS RGB Buffer Active Filters Layout Considerations OUTLINE DIMENSIONS Revision History
