Datasheet AD8541, AD8542, AD8544 (Analog Devices) - 6
ОписаниеCMOS Rail-to-Rail General-Purpose Amplifiers
Страниц / Страница20 / 6 — AD8541/AD8542/AD8544. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table …
ВерсияG
Формат / Размер файлаPDF / 317 Кб
AD8541/AD8542/AD8544. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter Rating. Table 5. Package Type. θJA. θJC. Unit
AD8541/AD8542/AD8544 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Package Type θJA θJC Unit
64 предложений от 29 поставщиков
Усилители.Тип: входа/ выхода - Rail-to-RailВыходной ток: на канал - 30 мАСкорость: нарастания выходного напряжения (SR) - 920 мВ/ мксКоэффициент: подавления -...
AD8542ARMZ
от 15 ₽
AD8542ARMZ-REEL
29 ₽
ЭИК
AD8542ARMZ-REEL
от 119 ₽
AD8542ARMZ-REEL
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
link to page 6
AD8541/AD8542/AD8544 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4.
θ
Parameter Rating
JA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages and Supply Voltage (VS) 6 V measured using a standard 4-layer board, unless otherwise Input Voltage GND to VS specified. Differential Input Voltage1 ±6 V Storage Temperature Range −65°C to +150°C
Table 5.
Operating Temperature Range −40°C to +125°C
Junction Temperature Range −65°C to +150°C 5-Lead SC70 (KS) 376 126 °C/W Lead Temperature (Soldering, 60 sec) 300°C 5-Lead SOT-23 (RJ) 190 92 °C/W 1 8-Lead SOIC (R) 120 45 °C/W For supplies less than 6 V, the differential input voltage is equal to ±VS. 8-Lead MSOP (RM) 142 45 °C/W Stresses above those listed under Absolute Maximum Ratings 8-Lead TSSOP (RU) 240 43 °C/W may cause permanent damage to the device. This is a stress 14-Lead SOIC (R) 115 36 °C/W rating only; functional operation of the device at these or any 14-Lead TSSOP (RU) 112 35 °C/W other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
ESD CAUTION
device reliability. Rev. G | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION NOTES ON THE AD854X AMPLIFIERS Lower Supply Current for 1 MHz Gain Bandwidth Higher Output Current Better Performance at Lower Voltages APPLICATIONS NOTCH FILTER COMPARATOR FUNCTION PHOTODIODE APPLICATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
