Datasheet MCP6L1, MCP6L1R, MCP6L2, MCP6L4 (Microchip) - 6
ПроизводительMicrochip
ОписаниеMCP6L1 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 200uA and an offset voltage that is 1 mV (typ)
Страниц / Страница36 / 6 — MCP6L1/1R/2/4. Note:. 1.E-02. 10m. 1.E. -03. -04. d 100µ. itu. -05. 10µ. …
MCP6L1/1R/2/4. Note:. 1.E-02. 10m. 1.E. -03. -04. d 100µ. itu. -05. 10µ. s (V. e 4. -06. ag lt. 1.E-07. o 3. t M 100n. t V. -08. 10n. -09. t C. -10. 100p. t, Ou u. -11. 10p
MCP6L1/1R/2/4 Note: 1.E-02 10m 1.E -03 -04 d 100µ itu -05 10µ s (V e 4 -06 ag lt 1.E-07 o 3 t M 100n t V -08 10n -09 t C -10 100p t, Ou u -11 10p
25 предложений от 14 поставщиков
Микросхема Операционный усилитель, MICROCHIP MCP6L1RT-E/OT Operational Amplifier, Single, 1 Amplifier, 2.8MHz, 2.3V/µs, 2.7V to 6V, SOT-23, 5Pins
MCP6L1RT-E/OT
от 8.76 ₽
MCP6L1RT-E/OT
39 ₽
MCP6L1RT-E/OT
от 113 ₽
MCP6L1RT-E/OT
MCP6L1/1R/2/4 Note:
Unless otherwise indicated, TA = +25°C, VDD = +5.0V, VSS = GND, VCM = VSS, VOUT = VDD/2, VL = VDD/2, RL = 10 kto VL and CL = 60 pF.
1.E-02 10m ) 6 1.E A -03 1m
G = +2 V/V VIN
( ) 1.E e -04 5 d 100µ
VOUT
1.E itu -05 10µ s (V n e 4 1.E g -06 a ag lt 1.E-07 o 3 t M 100n t V 1.E en -08 10n u rr 2 1.E u -09 1n
+125°C
tp
+85°C
1.E t C -10 100p 1 u
+25°C
t, Ou u 1.E p -11 10p
-40°C
In p 0 In 1.E-12 1p -1.0 -0.9 -0.8 -0.7 -0.6 -0.5 -0.4 -0.3 -0.2 -0.1 0.0 -1 0.E+00 5.E-06 1.E-05 2.E-05 2.E-05 3.E-05 Input Voltage (V) Time (5 µs/div) FIGURE 2-7:
Measured Input Current vs.
FIGURE 2-10:
The MCP6L1/1R/2/4 Show Input Voltage (below VSS). No Phase Reversal.
120 0 300 100 -30 t 250 B) (°) ) A (d 80 -60 rren ase 200
Phase
u h 60 Gain -90 P t C ifier (µ p n 150 o pl o 40 -120 oop m
Gain
-L 100 iesce r a
-40°C
en 20 -150 en-L u Q pe
+25°C
50 Op Op
+85°C
0 -180
+125°C
0 -20 -210 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.E- 0.1 1.E1+ 1.E+ 10 1.E+ 100 1.E+ 1k 1.E 10 +k 1. 1 E+ 00k 1.E+ 1M 1.E+ 10M 01 00 01 02 Frequ 03 ency 04 (Hz) 05 06 07 Power Supply Voltage (V) FIGURE 2-8:
Open-Loop Gain, Phase vs.
FIGURE 2-11:
Quiescent Current vs. Frequency. Power Supply Voltage.
1,000 40 ) A 30 m t ( 20 n rre 10
-40°C
u
+25°C
100 0 it C
+85°C
(nV/Hz)
+125°C
-10 ircu t C -20 hor -30 Input Noise Voltage Density S 10 -40 1.E-01 0.1 1.E+0 1 1.E+0 10 1.E+0 100 1.E+0 1k 1.E+0 10k 1.E+0 100k 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 1 2 3 Frequency (Hz) 4 5 Power Supply Voltage (V) FIGURE 2-9:
FIGURE 2-12:
Output Short Circuit Current vs. Frequency. vs. Power Supply Voltage. DS22135C-page 6  2009-2012 Microchip Technology Inc. Document Outline MCP6L1/1R/2/4 - 2.8 MHz, 200 μA Op Amps 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuit FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common-Mode Input Voltage at VDD = 2.7V. FIGURE 2-2: Input Offset Voltage vs. Common-Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Ambient Temperature. FIGURE 2-4: Input Common-Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L1/1R/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Power Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom to Output Current vs. Output Current. FIGURE 2-14: Small Signal, Non-Inverting Pulse Response. FIGURE 2-15: Large Signal, Non-Inverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Inputs FIGURE 4-1: Protecting the Analog Inputs. FIGURE 4-2: Unity Gain Buffer has a Limited VOUT Range. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-3: Output Resistor, RISO, Stabilizes Large Capacitive Loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-4: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-5: Example Guard Ring Layout. 4.7 Application Circuits FIGURE 4-6: Sallen Key Topology. FIGURE 4-7: Multiple Feedback Topology. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product Identification System Worldwide Sales and Service
