Datasheet LT1787, LT1787HV (Analog Devices) - 5
Описание | Precision, High Side Current Sense Amplifiers |
Страниц / Страница | 16 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply … |
Формат / Размер файла | PDF / 283 Кб |
Язык документа | английский |
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the temperature range –40
16 предложений от 15 поставщиков LINEAR TECHNOLOGY LT1787IS8#TRPBF Current Sense Amplifier, Precision, 1 Amplifier, SOIC, 8Pins, -40℃, 85℃ |
| LT1787IS8#TRPBF Linear Technology | 283 ₽ | |
| LT1787IS8#TRPBF Analog Devices | 343 ₽ | |
| LT1787IS8#TRPBF Linear Technology | по запросу | |
LT1787/LT1787HV
ELECTRICAL CHARACTERISTICS The
C
TA
85
C, otherwise specifications are at T – A = 25
C. Total supply = (VS – VEE) = 2.5V to 36V (LT1787I), 2.5V to 60V (LT1787HVI) unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Unipolar Output VSENSE = 2mV, VBIAS = 0V 32 50 mV Saturation Voltage VSENSE = 4mV, VBIAS = 0V 38 55 mV VSENSE = 5mV, VBIAS = 0V 43 60 mV VSENSE = 6mV, VBIAS = 0V 49 65 mV VSENSE = 2mV, VBIAS = 0V ● 32 56 mV VSENSE = 4mV, VBIAS = 0V ● 38 61 mV VSENSE = 5mV, VBIAS = 0V ● 43 66 mV VSENSE = 6mV, VBIAS = 0V ● 49 71 mV V + OMAX Maximum Output Voltage VS – 0.75 V RG1A, RG2A Input Gain-Setting Resistor Pin 1 to Pin 2, Pin 7 to Pin 8 1.25 kΩ ROUT Output Resistor Pin 5 to Pin 6 20 kΩ
The
C
TA
125
C. Total supply = (VS – VEE) = 2.5V to 36V (LT1787H), 2.5V to 60V (LT1787HVH) unless otherwise specified. (Note 5)
V – + S , VS Sense Amplifier Supply Voltage Single Supply Operation (LT1787H) ● 2.5 36 V Single Supply Operation (LT1787HVH) ● 2.5 60 V V + – SENSE Input Sense Voltage Full Scale VSENSE = VS – VS , VS = 10V, VBIAS = 5V, AV = 8 ±10% ● 500 mV VOS Input Offset Voltage IOUT = 0, VS Supply = 5V – 75 ±40 75 µV – 40°C ≤ TA ≤ 125°C ● – 400 400 µV IOUT = 0 (LT1787H) – 100 100 µV – 40°C ≤ TA ≤ 125°C ● – 550 550 µV IOUT = 0 (LT1787HVH) – 100 100 µV – 40°C ≤ TA ≤ 125°C ● – 550 550 µV VOS TC Temperature Coefficient of VOS VS Supply = 5V (Note 6) ● 0.5 4 µV/°C IOUT(O) No-Load Output Current Error VSENSE = 0V 4 nA VOUT(O) No-Load Output Voltage Error VSENSE = 0V, VS Supply = 5V –600 600 µV – 40°C ≤ TA ≤ 125°C ● –3200 3200 µV gm Tranconductance, IOUT/ VSENSE ±VSENSE = 10mV, 50mV, 100mV, 150mV, 250mV, 400 µA/V VS Supply = Total Supply + |VSENSE| AV Gain, VOUT/ VSENSE ±VSENSE = 100mV, VS Supply = 5V ● 7.76 8 8.24 V/V Output Voltage Gain Error ±VSENSE = 100mV, VS Supply = 5V ● – 3 1 3 % VS PSRR VS Supply Rejection Ratio VSENSE = 0V, VS Supply = 2.5V to 36V (LT1787H) ● 100 130 dB VSENSE = 0V, VS Supply = 2.5V to 60V (LT1787HVH) ● 100 130 dB VEE PSRR Negative Supply Rejection Ratio VSENSE = 0V, VS Supply = 15V, VBIAS = 0V, ● 100 130 dB VEE = – 1V to – 15V (LT1787H) VSENSE = 0V, VS Supply = 40V, VBIAS = 0V, ● 100 130 dB VEE = – 1V to – 15V (LT1787HVH) ∆VOS Change in Input Offset Voltage VSENSE = 0V, VS Supply = 36V, VBIAS = 0.5V to 25V (LT1787H) ● 100 130 dB ∆VBIAS with Change in VBIAS Voltage VSENSE = 0V, VS Supply = 60V, VBIAS = 0.5V to 25V (LT1787HVH) ● 100 130 dB I + S (O) Positive Input Sense Current VSENSE = 0V ● 10 25 µA I – S (O) Negative Input Sense Current VSENSE = 0V ● 50 115 µA IEE(O) Negative Supply Current VSENSE = 0V ● 60 140 µA IOUT Output Current VSENSE = ±128mV ±50 µA V + OUT Output Voltage VSENSE = ±128mV, VS ≥ 3.3V VBIAS ±1.024 V Ripple Rejection V + – S = VS = 20V, ∆VS Supply = 1V, f = 1kHz ● 80 88 dB 1787fc 5
