Datasheet SFH 213 FA (OSRAM) - 2
ПроизводительOSRAM
ОписаниеSilicon PIN Photodiode
Страниц / Страница9 / 2 — Version 1.3. SFH 213 FA. Maximum Ratings. Parameter. Symbol. Values. …
Формат / Размер файлаPDF / 274 Кб
Version 1.3. SFH 213 FA. Maximum Ratings. Parameter. Symbol. Values. Unit. Characteristics
Version 1.3 SFH 213 FA Maximum Ratings Parameter Symbol Values Unit Characteristics
36 предложений от 21 поставщиков
Фотодиод инфракрасного спектра — 5мм с малым временем переключения 900н
Промэлектроника
SFH213FA
41 ₽
МосЧип
SFH213FA/BPV10NF
Siemens
SFH213FA
OSRAM
727GS
SFH213FA
(TA = 25 °C)
Operating and storage temperature range T ; T -40 ... 100 °C op stg Reverse voltage V 20 V R Reverse voltage V 50 V R (t < 2 min) Total Power dissipation P 150 mW tot ESD withstand voltage VESD 2000 V (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
Characteristics
(TA = 25 °C)
Photocurrent (typ (min)) IP 90 (≥ 65) µA (V = 5 V, λ = 870 nm, E = 1 mW/cm2) R e Wavelength of max. sensitivity (typ) λ 900 nm S max Spectral range of sensitivity (typ) λ (typ) 750 nm 10% ... 1100 Radiant sensitive area (typ) A 1.00 mm2 Dimensions of radiant sensitive area (typ) L x W 1 x 1 mm x mm Half angle (typ) ϕ ± 10 ° Dark current (typ (max)) IR 1 (≤ 5) nA (V = 20 V) R Spectral sensitivity of the chip (typ) S 0.65 A / W λ typ (λ = 870 nm) Quantum yield of the chip (typ) η 0.93 Electro (λ = 870 nm) ns /Photon Open-circuit voltage (typ (min)) VO 380 (≥ 300) mV (E = 0.5 mW/cm2, λ = 870 nm) e Short-circuit current (typ) I 42 µA SC (E = 0.5 mW/cm2, λ = 870 nm) e Rise and fall time (typ) t , t 0.005 µs r f (VR = 20 V, RL = 50 Ω, λ = 850 nm) Forward voltage (typ) VF 1.3 V (IF = 100 mA, E = 0) Capacitance (typ) C0 11 pF (V = 0 V, f = 1 MHz, E = 0) R Temperature coefficient of V (typ) TC -2.6 mV / K O V 2015-12-23 2 Document Outline Features: Applications Ordering Information Maximum Ratings Characteristics Relative Spectral Sensitivity Photocurrent / Open-Circuit Voltage Dark Current Capacitance Dark Current Directional Characteristics Package Outline Disclaimer Glossary
