Datasheet AD8479 - 2
ОписаниеVery High Common-Mode Voltage Precision Difference Amplifier
Страниц / Страница17 / 2 — AD8479* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
Формат / Размер файлаPDF / 464 Кб
AD8479* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Press. EVALUATION KITS
AD8479* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Press EVALUATION KITS
Микросхема Буферный усилитель, IC OPAMP GP 130kHz RRO 8SOIC
AD8479BRZ-RL
189 ₽
AD8479BRZ-RL
557 ₽
AD8479BRZ-RL
978 ₽
AD8479BRZ-RL
View a parametric search of comparable parts.
Press
• High Common-Mode Voltage Difference Amplifier
EVALUATION KITS
Enables Direct Interface to High Voltage Input up to ±600 V • AD8479 Evaulation Board for the Precision Difference Amplifier
DESIGN RESOURCES DOCUMENTATION
• AD8479 Material Declaration
Application Notes
• PCN-PDN Information • AN-1308: Common-Mode Step Response of Current Sense • Quality And Reliability Amplifiers • Symbols and Footprints • AN-1344: High Common-Mode Voltage Current Loop Transmitter Front End
DISCUSSIONS
• AN-1375: Output Current Monitoring of High Voltage View all AD8479 EngineerZone Discussions. Class D Amplifiers
Data Sheet SAMPLE AND BUY
• AD8479: Very High Common-Mode Voltage Precision Visit the product page to see pricing options. Difference Amplifier Data Sheet
Technical Books TECHNICAL SUPPORT
• A Designer's Guide to Instrumentation Amplifiers, 3rd Edition, 2006 Submit a technical question or find your regional support number.
User Guides
• AD8479: Evaluation Board for the Precision Difference
DOCUMENT FEEDBACK
Amplifier (Wiki site) Submit feedback for this data sheet.
TOOLS AND SIMULATIONS
• AD8479 SPICE Macro Model
Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Single-Supply Operation System-Level Decoupling and Grounding Using a Large Shunt Resistor Output Filtering Gain of 60 Differential Amplifier Error Budget Analysis Example Outline Dimensions Ordering Guide
