Datasheet RHRG75120 - Fairchild Даташит Диод, HYPERFAST — Даташит
Наименование модели: RHRG75120
Купить RHRG75120 на РадиоЛоцман.Цены — от 4.40 до 12 616 ₽ 28 предложений от 17 поставщиков Диод выпрямительный общего применения 1200В 75А | |||
RHRG75120 ON Semiconductor | от 4.40 ₽ | ||
RHRG75120 ON Semiconductor | 186 ₽ | ||
RHRG75120 ON Semiconductor | 350 ₽ | ||
RHRG75120_Q Fairchild | по запросу |
Производитель: Fairchild
Описание: Диод, HYPERFAST
RHRG75120
Data Sheet October 2008
75A, 1200V Hyperfast Diode
The RHRG75120 is a hyperfast diode with soft recovery characteristics (trr < 85ns).
It has half the recovery time of ultrafast diodes and is silicon nitride passivated ion-implanted epitaxial planar construction. This device is intended for use as a freewheeling/clamping diode and rectifier in a variety of high frequency switching power supplies and other power switching applications. Its low stored charge and hyperfast soft recovery characteristic minimize ringing and electrical noise in many power switching circuits, thus reducing power loss in the switching transistors. Formerly developmental type TA49042.
Features
- Diode Type: Soft Recovery
- Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
- Forward Current If(AV): 75 А
- Forward Voltage VF Max: 3.2 В
- Reverse Recovery Time trr Max: 85 нс
- Forward Surge Current Ifsm Max: 500 А
- Тип корпуса: TO-247
- Количество выводов: 2
- SVHC: No SVHC (15-Dec-2010)
- Current Ifsm: 500 А
- Forward Voltage: 3.2 В
- Температура перехода максимальная: 175°C
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Fischer Elektronik - FK 243 MI 247 H
- Fischer Elektronik - FK 243 MI 247 O
- Fischer Elektronik - SK 145/25 STS-220
- Fischer Elektronik - WLK 5
