Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet PCA9635PW,112 - NXP Даташит — Даташит
Наименование модели: PCA9635PW,112
NXP PCA9635PW,112 LED Driver, 2.3V to 5.5V input, 16Outputs, 1MHz switch-freq., 5.5V/25mA out, TSSOP-28
PCA9635PW,112
88 ₽
PCA9635PW,112
163 ₽
PCA9635PW,112
205 ₽
T-electron
PCA9635PW.112
43 094 ₽
Производитель: NXP
data sheetСкачать Data Sheet
PCA9635
16-bit Fm+ I2C-bus LED driver
Rev.
07 -- 16 July 2009 Product data sheet
1. General description
The PCA9635 is an I2C-bus controlled 16-bit LED driver optimized for Red/Green/Blue/Amber (RGBA) color mixing applications. Each LED output has its own 8-bit resolution (256 steps) fixed frequency individual PWM controller that operates at 97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value. Each LED output can be off, on (no PWM control), set at its individual PWM controller value or at both individual and group PWM controller values. The LED output driver is programmed to be either open-drain with a 25 mA current sink capabil
  • Количество выходов: 16
  • Выходной ток: 25 мА
  • Выходное напряжение: 5.5 В
  • Диапазон входных напряжений: 2.3 В ... 5.5 В
  • Dimming Control Type: ШИМ
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: TSSOP
  • Switching Frequency: 1 МГц
PCA9635PW112, PCA9635PW 112
На английском языке: Datasheet PCA9635PW,112 - NXP
