Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet MAX4544EUT+T - Maxim Даташит Аналоговый переключатель / мультиплексор (MUX) ИС — Даташит
Maxim MAX4544EUT+T
Наименование модели: MAX4544EUT+T
73 предложений от 28 поставщиков
Микросхема Чип аналогового переключателя, MAXIM INTEGRATED PRODUCTS MAX4544EUT+T. Analogue Switch, Dual Channel, SPDT, 1Channels, 60Ω, 2.7V to 12V, SOT-23, 6Pins
MAX4544EUT+T
Maxim
от 33 ₽
MAX4544EUT+T
Maxim
59 ₽
МосЧип
MAX4544EUT-T
Maxim
MAX4544EUT+T
Производитель: Maxim
Описание: Аналоговый переключатель / мультиплексор (MUX) ИС
data sheetСкачать Data Sheet
19-1202; Rev 4; 6/07
Low-Voltage, Single-Supply Dual SPST/SPDT Analog Switches
General Description
The MAX4541­MAX4544 are precision, dual analog switches designed to operate from a single +2.7V to +12V supply.
Low power consumption (5µW) makes these parts ideal for battery-powered equipment. These switches offer low leakage currents (100pA max) and fast switching speeds (tON = 150ns max, tOFF = 100ns max). When powered from a +5V supply, the MAX4541­ MAX4544 offer 2 max matching between channels, 60 max on-resistance (RON), and 6 max RON flatness. These switches also offer 5pC max charge injection and a minimum of 2000V ESD protection per Method 3015.7. The MAX4541/MAX4542/MAX4543 are dual single-pole/ single-throw (SPST) devices and the MAX4544 is a singlepole/double-throw (SPDT) device. The MAX4541 has two normally open (NO) switches and the MAX4542 has two normally closed (NC) switches. The MAX4543 has one NO and one NC switch and can be used as an SPDT, while the MAX4544 is an SP
На английском языке: Datasheet MAX4544EUT+T - Maxim ANALOG SWITCH / MULTIPLEXER (MUX) IC
