Datasheet MAX4427CPA+ - Maxim Даташит ИС ((NW)) — Даташит
Maxim MAX4427CPA+
Наименование модели: MAX4427CPA+
27 предложений от 15 поставщиков
Интегральные схемы (ИС) усилителей мощности Dual High-Speed 1.5A MOSFET Driver
MAX4427CPA
Maxim
82 ₽
T-electron
MAX4427CPA
Maxim
178 ₽
HXD Co.
MAX4427CPA+
Maxim
724 ₽
MAX4427CPA+
Вебинар «Как выбрать идеальный силовой модуль: решения SUNCO для силовой электроники» (03.12.2024)
Производитель: Maxim
Описание: ИС ((NW))
data sheetСкачать Data Sheet
19-0132; Rev 2; 6/06
Dual High-Speed 1.5A MOSFET Drivers
General Description
The MAX4426/MAX4427/MAX4428 are dual monolithic MOSFET drivers designed to translate TTL/CMOS inputs to high voltage/current outputs.
The MAX4426 is a dual inverting power MOSFET driver. The MAX4427 is a dual noninverting power MOSFET driver, and the MAX4428 contains one inverting section and one noninverting section. Delay times are nearly independent of VDD (see Typical Operating Characteristics). High-current output drivers rapidly charge and discharge the gate capacitance of even the largest power MOSFETs to within millivolts of the supply rails. This produces the power MOSFETs' minimum on resistance. The MAX4426/ MAX4427/MAX4428's high speed minimizes power losses in switching power supplies and DC-DC converters. S Lower On Resistance: 4 vs. 7 S Shorter Delay Times: tD1 - 10ns vs. 30ns tD2 - 25ns vs. 50ns S 1.5A Peak Output Current S Fast Rise and Fall Times: Typically 20ns with 1000pF Load S Wide Operat
На английском языке: Datasheet MAX4427CPA+ - Maxim IC ((NW))
