Источники питания Keen Side
Datasheet LTC3105EDD - Linear Technology Даташит — Даташит
Наименование модели: LTC3105EDD
41 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Стабилизаторы напряжения - Специальное назначение
727GS
LTC3105EDD#TRPBF
от 28 ₽
LTC3105EDD#TRPBF
от 124 ₽
LTC3105EDD#PBF
812 ₽
TradeElectronics
LTC3105EDD#PBF
Производитель: Linear Technology
data sheetСкачать Data Sheet
LTC3105 400mA Step-Up DC/DC Converter with Maximum Power Point Control and 250mV Start-Up FEATURES
n n n n n n n n n n n n
DESCRIPTION
The LTC®3105 is a high efficiency step-up DC/DC converter that can operate from input voltages as low as 225mV.
A 250mV start-up capability and integrated maximum power point controller (MPPC) enable operation directly from low voltage, high impedance alternative power sources such as photovoltaic cells, TEGs (thermoelectric generators) and fuel cells. A user programmable MPPC set point maximizes the energy that can be extracted from any power source. Burst Mode operation, with a proprietary self adjusting peak current, optimizes converter efficiency and output voltage ripple over all operating conditions. The AUX powered 6mA LDO provides a regulated rail for external microcontrollers and sensors while the main output is charging. In shutdown, IQ is reduced to 10µA and integrated thermal shutdown offers protection from overtemperature faults. The LTC31
  • Входное напряжение минимальное: 5 В
  • Количество выходов: 1
  • Выходное напряжение: 5.25 В
  • Выходной ток: 400 мА
  • Количество выводов: 10
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Pb-Free: Yes
  • Peak Reflow Compatible (260 C): Yes
На английском языке: Datasheet LTC3105EDD - Linear Technology
