Datasheet IRS2336DJPBF - International Rectifier Даташит ИС, полевой транзистор драйвер, HIGH/LOW SIDE, LCC-44 — Даташит
Наименование модели: IRS2336DJPBF
![]() 17 предложений от 15 поставщиков IC: driver; 3-фазный мост IGBT,3-фазный мост MOSFET; PLCC44 | |||
IRS2336DJPBF Infineon | от 60 ₽ | ||
IRS2336DJPBF Infineon | 252 ₽ | ||
IRS2336DJPBF Infineon | 378 ₽ | ||
IRS2336DJPBF. International Rectifier | по запросу |
Описание: ИС, полевой транзистор драйвер, HIGH/LOW SIDE, LCC-44
October 16, 2009
IRS2336(D) IRS23364D
HIGH VOLTAGE 3 PHASE GATE DRIVER IC Features
· · · · · · · · · · · · · · · · · · · Drives up to six IGBT/MOSFET power devices Gate drive supplies up to 20 V per channel Integrated bootstrap functionality (IRS2336(4)D) Over-current protection Over-temperature shutdown input Advanced input filter Integrated deadtime protection Shoot-through (cross-conduction) protection Undervoltage lockout for VCC & VBS Enable/disable input and fault reporting Adjustable fault clear timing Separate logic and power grounds 3.3 V input logic compatible Tolerant to negative transient voltage Designed for use with bootstrap power supplies Matched propagation delays for all channels -40° to 125° operating range C C RoHS compliant Lead-Free
Product Summary
- Device Type: High Side / Low Side
- Module Configuration: High Side / Low Side
- Peak Output Current: 350 мА
- Входное сопротивление: 50 Ом
- Input Delay: 530 нс
- Output Delay: 530 нс
