Datasheet LTC4012IUF-1 - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 20QFN — Даташит
Наименование модели: LTC4012IUF-1
Купить LTC4012IUF-1 на РадиоЛоцман.Цены — от 385 до 2 556 ₽ 16 предложений от 12 поставщиков Battery Charger/Constant Current/Constant Voltage Lead-Acid/Li-Ion/Li-Pol/NiCD/NiMH 4mA 2V to 28V 20Pin QFN EP T/R | |||
LTC4012IUF-1#PBF Analog Devices | 385 ₽ | ||
LTC4012IUF-1#TRPBF Linear Technology | 438 ₽ | ||
LTC4012IUF-1#TRPBF Linear Technology | 465 ₽ | ||
LTC4012IUF-1#TRPBF Analog Devices | по запросу |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 20QFN
Your Electronic Engineering Resource
LTC4012IUF-1#PBF - Li-Ion, Battery Charger IC
General Description:
The LTC4012 is a constant-current /constant-voltage battery charger controller.
It uses a synchronous quasi-constant frequency PWM control architecture that will not generate audib le noise with ceramic bulk capacitors. Charge current is set by external resistors and can be monitored as an output voltage. With no built-in termination, the LTC4012 family charges a wide range of batteries under external control. The LTC4012 features fully adjustable output voltage, while the LTC4012-1 and LTC4012-2 can be pin-programmed for Lithium-Ion/Polymer battery packs of 1-, 2-, 3- or 4-series cells. The LTC4012-1 provides output voltage of 4.1V/cell and the LTC4012-2 is a 4.2V/cell version. The device includes AC adapter input current limiting, which maximizes charge rate for a fixed input power level. An external sense resistor programs the input current limit, and the ICL status pin indic
- Входное напряжение: 28 В
- Charge Current Max: 4 А
- Battery IC Case Style: QFN
- Количество выводов: 20
- SVHC: No SVHC (15-Dec-2010)
- Входное напряжение максимальное: 28 В
- Выходное напряжение максимальное: 28 В
- Диапазон напряжения питания: 6 В ... 28 В
LTC4012IUF1, LTC4012IUF 1
