Клеммные колодки Keen Side
Datasheet LTC1760CFW - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 4.28 А, TSSOP-48 — Даташит
Linear Technology LTC1760CFW
Наименование модели: LTC1760CFW
36 предложений от 21 поставщиков
Интегральные микросхемы Силовые чипы — зарядники батарей
LIXINC Electronics
LTC1760CFW#PBF
от 392 ₽
LTC1760CFW#TRPBF
684 ₽
Элитан
LTC1760CFW
2 869 ₽
ЗУМ-СМД
LTC1760CFW#PBF
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 4.28 А, TSSOP-48
data sheetСкачать Data Sheet
LTC1760 Dual Smart Battery System Manager DESCRIPTIO
The LTC®1760 Smart Battery System Manager is a highly integrated level 3 battery charger and selector intended for products using dual smart batteries.
Three SMBus interfaces allow the LTC1760 to servo to the internal voltage and currents measured by the batteries while allowing an SMBus Host to monitor either battery's status. Charging accuracy is determined by the battery's internal voltage and current measurement, typically better than ±0.2%. A proprietary PowerPathTM architecture supports simultaneous charging or discharging of both batteries. Typical battery run times are extended by up to 10%, while charging times are reduced by up to 50%. The LTC1760 automatically switches between power sources in less than 10µs to prevent power interruption upon battery or wall adapter removal. The LTC1760 implements all elements of a version 1.1 "Smart Battery System Manager" except for the generation of composite battery information. An int
  • Входное напряжение: 28 В
  • Battery Charge Voltage: 28 В
  • Charge Current Max: 4.28 А
  • Battery IC Case Style: TSSOP
  • Количество выводов: 48
  • Number of Series Cells: 2
  • Рабочий диапазон температрур: 0°C ... +70°C
На английском языке: Datasheet LTC1760CFW - Linear Technology IC, BATTERY CHARGER, 4.28 A, TSSOP-48
