Datasheet DS90CF388VJD/NOPB - National Semiconductor Даташит ИС, RECEIVER — Даташит
Наименование модели: DS90CF388VJD/NOPB
![]() 25 предложений от 15 поставщиков TEXAS INSTRUMENTS DS90CF388VJD/NOPB LVDS Driver, Dual Pixel, LVDS Receiver, 300mA, -10℃, 70℃, 3V | |||
DS90CF388VJD/NOPB Texas Instruments | 460 ₽ | ||
DS90CF388VJD/NOPB Texas Instruments | 610 ₽ | ||
DS90CF388VJD/NOPB Texas Instruments | 874 ₽ | ||
DS90CF388VJD/NOPB National Semiconductor | по запросу |
Описание: ИС, RECEIVER
DS90C387/DS90CF388 Dual Pixel LVDS Display Interface (LDI)-SVGA/QXGA
February 2006
General Description
The DS90C387/DS90CF388 transmitter/receiver pair is designed to support dual pixel data transmission between Host and Flat Panel Display up to QXGA resolutions.
The transmitter converts 48 bits (Dual Pixel 24-bit color) of CMOS/TTL data into 8 LVDS (Low Voltage Differential Signalling) data streams. Control signals (VSYNC, HSYNC, DE and two user-defined signals) are sent during blanking intervals. At a maximum dual pixel rate of 112MHz, LVDS data line speed is 672Mbps, providing a total throughput of 5.38Gbps (672 Megabytes per second). Two other modes are also supported. 24-bit color data (single pixel) can be clocked into the transmitter at a maximum rate of 170MHz. In this mode, the transmitter provides single-to-dual pixel conversion, and the output LVDS clock rate is 85MHz maximum. The third mode provides inte
- Диапазон напряжения питания: 3 В ... 3.6 В
- Рабочий диапазон температрур: -10°C ... +70°C
- Тип корпуса: TQFP
- Количество выводов: 100
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 90
- Способ монтажа: SMD
- Скорость передачи данных: 784 Mbps
- Интерфейс: LVDS
- Количество приемников: 9
- Propagation Delay: 0.5 нс
- Ток потребления: 250 мА
