Datasheet RFD16N06LESM - Fairchild Даташит Полевой транзистор, N, D-PAK — Даташит
Наименование модели: RFD16N06LESM
Купить RFD16N06LESM на РадиоЛоцман.Цены — от 17 до 4 942 ₽ 30 предложений от 15 поставщиков Power Field-Effect Transistor, 16A I(D), 60V, 0.047ohm, 1-Element, N-Channel, Silicon, Metal-oxide Semiconductor FET, TO-252AA | |||
RFD16N06LESM9A | от 17 ₽ | ||
RFD16N06LESM9A ON Semiconductor | 88 ₽ | ||
RFD16N06LESM9A ON Semiconductor | 167 ₽ | ||
RFD16N06LESM9A Fairchild | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор, N, D-PAK
RFD16N06LESM
Data Sheet September 2002
16A, 60V, 0.047 Ohm, Logic Level, N-Channel Power MOSFETs
These are N-Channel power MOSFETs manufactured using a modern process.
This process, which uses feature sizes approaching those of LSI integrated circuits gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers, relay drivers and emitter switches for bipolar transistors. This performance is accomplished through a special gate oxide design which provides full rated conductance at gate bias in the 3V to 5V range, thereby facilitating true on-off power control directly from logic level (5V) integrated circuits. Formerly developmental type TA49027.
Features
- Continuous Drain Current Id: 16 А
- Drain Source Voltage Vds: 60 В
- On Resistance Rds(on): 47 МОм
- Rds(on) Test Voltage Vgs: 5 В
- Voltage Vgs Max: 10 В
- Рабочий диапазон температрур: -55°C ... +175°C
- Корпус транзистора: D-PAK
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Альтернативный тип корпуса: D-PAK
- Current Id Max: 16 А
- Тип корпуса: DPAK
- Power Dissipation Pd: 90 Вт
- SMD Marking: RFD16N06LESM
- Способ монтажа: SMD
- Threshold Voltage Vgs Typ: 3 В
- Voltage Vds Typ: 60 В
- Voltage Vgs Rds on Measurement: 5 В
Дополнительные аксессуары:
- Fischer Elektronik - FK 244 08 D PAK
- Fischer Elektronik - FK 244 13 D PAK
- Fischer Elektronik - WLK 5
