Клеммные колодки Keen Side
Datasheet RFD14N05LSM - Fairchild Даташит Полевой транзистор, N, LOGIC, D-PAK — Даташит
Fairchild RFD14N05LSM
Наименование модели: RFD14N05LSM
41 предложений от 23 поставщиков
N-канальный Полевой транзистор (Vds=50V, Id=14A, Rds=0.1 R, P=48W, -55 to +175C), логический уровень переключателя.
Akcel
RFD14N05LSM9A
от 29 ₽
RFD14N05LSM9A
31 ₽
LIXINC Electronics
RFD14N05LSM
Allelco
RFD14N05LSM9A
Производитель: Fairchild
Описание: Полевой транзистор, N, LOGIC, D-PAK
data sheetСкачать Data Sheet
RFD14N05L, RFD14N05LSM, RFP14N05L
Data Sheet January 2002
14A, 50V, 0.100 Ohm, Logic Level, N-Channel Power MOSFETs
These are N-channel power MOSFETs manufactured using the MegaFET process.
This process, which uses feature sizes approaching those of LSI integrated circuits, gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers and relay drivers. This performance is accomplished through a special gate oxide design which provides full rated conductance at gate bias in the 3V-5V range, thereby facilitating true on-off power control directly from logic level (5V) integrated circuits. Formerly developmental type TA09870.
Features
  • Continuous Drain Current Id: 14 А
  • Drain Source Voltage Vds: 50 В
  • On Resistance Rds(on): 100 МОм
  • Rds(on) Test Voltage Vgs: 5 В
  • Voltage Vgs Max: 2 В
  • Рабочий диапазон температрур: -55°C ... +175°C
  • Корпус транзистора: D-PAK
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Альтернативный тип корпуса: D-PAK
  • Current Id Max: 14 А
  • Current Temperature: 25°C
  • Количество транзисторов: 1
  • Тип корпуса: DPAK
  • Power Dissipation Pd: 48 Вт
  • Pulse Current Idm: 20 А
  • SMD Marking: RFD14N05
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 2 В
  • Voltage Vds Typ: 50 В
  • Voltage Vgs Rds on Measurement: 5 В
  • Voltage Vgs th Max: 2 В
RoHS: Y-Ex
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 08 D PAK
  • Fischer Elektronik - FK 244 13 D PAK
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet RFD14N05LSM - Fairchild MOSFET, N, LOGIC, D-PAK
