Источники питания Keen Side
Datasheet HUF75639G3 - Fairchild Даташит Полевой транзистор — Даташит
Fairchild HUF75639G3
Наименование модели: HUF75639G3
40 предложений от 18 поставщиков
Силовой МОП-транзистор, N Канал, 100 В, 56 А, 0.025 Ом, TO-247, Through Hole
IC Home
HUF75639G3
302 ₽
HUF75639G3
от 337 ₽
T-electron
HUF75639G3
Fairchild
МосЧип
HUF75639G3
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор
data sheetСкачать Data Sheet
HUF75639G3, HUF75639P3, HUF75639S3S, HUF75639S3
Data Sheet December 2001
56A, 100V, 0.025 Ohm, N-Channel UltraFET Power MOSFETs
These N-Channel power MOSFETs are manufactured using the innovative UltraFET® process.
This advanced process technology achieves the lowest possible on-resistance per silicon area, resulting in outstanding performance. This device is capable of withstanding high energy in the avalanche mode and the diode exhibits very low reverse recovery time and stored charge. It was designed for use in applications where power efficiency is important, such as switching regulators, switching converters, motor drivers, relay drivers, lowvoltage bus switches, and power management in portable and battery-operated products. Formerly developmental type TA75639.
Features
  • Continuous Drain Current, Id: 56 А
  • Drain Source Voltage, Vds: 100 В
  • On Resistance, Rds(on): 0.025 Ом
  • Rds(on) Test Voltage, Vgs: 10 В
  • Threshold Voltage, Vgs Typ: 4 В
  • Рассеиваемая мощность: 200 Вт
RoHS: Y-Ex
Дополнительные аксессуары:
  • WAKEFIELD SOLUTIONS - 657-25ABPE
На английском языке: Datasheet HUF75639G3 - Fairchild MOSFET
