Datasheet FDS6982AS - Fairchild Даташит Полевой транзистор, NN-CH, 30 В, 8.6 А, 8-SOIC, RL — Даташит
Наименование модели: FDS6982AS
Купить FDS6982AS на РадиоЛоцман.Цены — от 37 до 2 718 ₽ 29 предложений от 23 поставщиков Dual Notebook Power Supply N-Channel PowerTrench® SyncFETTM 30V, 2500-REEL | |||
FDS6982AS | от 37 ₽ | ||
FDS6982AS Freescale | 38 ₽ | ||
FDS6982AS ON Semiconductor | 41 ₽ | ||
FDS6982AS ON Semiconductor | 77 ₽ |
Производитель: Fairchild
Описание: Полевой транзистор, NN-CH, 30 В, 8.6 А, 8-SOIC, RL
FDS6982AS
May 2008
FDS6982AS
General Description
The FDS6982AS is designed to replace two single SO8 MOSFETs and Schottky diode in synchronous DC:DC power supplies that provide various peripheral voltages for notebook computers and other battery powered electronic devices.
FDS6982AS contains two unique 30V, N-channel, logic level, PowerTrench MOSFETs designed to maximize power conversion efficiency. The high-side switch (Q1) is designed with specific emphasis on reducing switching losses while the low-side switch (Q2) is optimized to reduce conduction losses. Q2 also includes an integrated Schottky diode using Fairchild's monolithic SyncFET technology.
- Continuous Drain Current Id: 6.3 А
- Drain Source Voltage Vds: 30 В
- On Resistance Rds(on): 0.011 Ом
- Threshold Voltage Vgs Typ: 1.4 В
- Влагостойкость: MSL 1 - Unlimited
- Количество выводов: 8
- Корпус транзистора: SOIC
- Полярность транзистора: Dual N Channel
- Рабочий диапазон температрур: -55°C ... +150°C
- Рассеиваемая мощность: 2 Вт
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
