Datasheet FDG6320C - Fairchild Даташит Полевой транзистор, сдвоенный, NP, SMD, 6-SC-70 — Даташит
Fairchild FDG6320C
Наименование модели: FDG6320C
19 предложений от 17 поставщиков
Trans MOSFET N/P-CH 25V 0.22A/0.14A 6-Pin SC-70 T/R
T-electron
FDG6320C
667 ₽
TradeElectronics
FDG6320C_D87Z
Fairchild
МосЧип
FDG6320C_NL
Fairchild
FDG6320C_Q
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, NP, SMD, 6-SC-70
data sheetСкачать Data Sheet
November 1998
FDG6320C Dual N & P Channel Digital FET
General Description
These dual N & P-Channel logic level enhancement mode field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for bipolar digital transistors and small signal MOSFETS. Since bias resistors are not required, this dual digital FET can replace several different digital transistors, with different bias resistor values.
Features
  • Полярность транзистора: N and P Channel
  • Continuous Drain Current Id: 220 мА
  • Drain Source Voltage Vds: 25 В
  • On Resistance Rds(on): 4 Ом
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Threshold Voltage Vgs Typ: 850 мВ
  • Рассеиваемая мощность: 300 мВт
  • Корпус транзистора: SC-70
  • Количество выводов: 6
  • SVHC: No SVHC (19-Dec-2011)
  • Current Id Max: 220 мА
  • Тип корпуса: SC-70
  • Способ монтажа: SMD
  • Voltage Vds Typ: 25 В
  • Voltage Vgs Max: 850 мВ
  • Voltage Vgs Rds on Measurement: 4.5 В
На английском языке: Datasheet FDG6320C - Fairchild MOSFET, DUAL, NP, SMD, 6-SC-70
