Datasheet Texas Instruments OPA349NA/250 — Даташит
Серия | OPA349 |
Модель | OPA349NA/250 |
1 мкА, Rail-to-Rail, операционные усилители КМОП 5-SOT-23 0–70
OPA349, OPA2349: 1uA, Rail-to-Rail, I/O, CMOS Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2004
![]() 44 предложений от 19 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA349NA/250 Operational Amplifier, Single, 1 Amplifier, 70kHz, 0.02V/µs, 1.8V to 5.5V, SOT-23, 5Pins | |||
OPA349NA/250 Texas Instruments | от 16 ₽ | ||
OPA349NA/250G4 Texas Instruments | 23 ₽ | ||
OPA349NA/250 Texas Instruments | 68 ₽ | ||
OPA349NA/250 Texas Instruments | от 168 ₽ |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | A49 |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 48 дБ |
CMRR(Typ) | 60 дБ |
GBW(Typ) | 0.07 МГц |
Input Bias Current(Max) | 10 pA |
Iq per channel(Max) | 0.002 мА |
Iq per channel(Typ) | 0.001 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 15 uV/C |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Current(Typ) | 8 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.02 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 1.8 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 300 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 10 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA349 (12)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=10uA)
