Datasheet Texas Instruments TLV2231CDBVR — Даташит
Серия | TLV2231 |
Модель | TLV2231CDBVR |
Одиночный операционный усилитель LinCMOS™ Rail-To-Rail uPower 5-SOT-23 0–70
Advanced LinCMOS Rail-to-Rail Low-Power Single Operational Amplifiers datasheet
PDF, 761 Кб, Версия: D, Файл опубликован: 3 апр 2001
![]() 18 предложений от 15 поставщиков Микросхема Операционный усилитель, Op Amp Single GP R-R O/P ±5V/10V 5Pin SOT-23 T/R | |||
TLV2231CDBVR Texas Instruments | от 18 ₽ | ||
TLV2231CDBVR Texas Instruments | 34 ₽ | ||
TLV2231CDBVR Texas Instruments | 135 ₽ | ||
TLV2231CDBVR Texas Instruments | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | VAEC |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 60 дБ |
CMRR(Typ) | 70 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 60 pA |
Iq per channel(Max) | 1.3 мА |
Iq per channel(Typ) | 0.85 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 1 uV/C |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Current(Typ) | 14 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.6 V/us |
Total Supply Voltage(Max) | 10 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 15 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Conditioning a Switch-mode Power Supply Current Signal Using TI Op AmpsPDF, 61 Кб, Файл опубликован: 23 мар 2000
The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp. - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2231 (8)
