Datasheet Texas Instruments OPA552PA — Даташит
СерияOPA552
МодельOPA552PA
Высоковольтные сильноточные операционные усилители 8-PDIP
OPA55x High-Voltage, High-Current Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2016
22 предложений от 14 поставщиков
Операционный усилитель, 1 Усилитель, 12 МГц, 24 В/мкс, ± 4В до ± 30В, DIP, 8 вывод(-ов)
OPA552PA
180 ₽
OPA552PA
209 ₽
OPA552PA
от 1 141 ₽
OPA552PA
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA552PA
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesDecompensated
АрхитектураFET
CMRR(Min)92 дБ
CMRR(Typ)102 дБ
GBW(Typ)12 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)8.5 мА
Iq per channel(Typ)7 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)380 мА
Package GroupPDIP
Rail-to-RailNo
Slew Rate(Typ)24 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA552PA
