Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Texas Instruments OPA1611AID — Даташит
СерияOPA1611
МодельOPA1611AID
1.1nV/в€љHz Noise, Low Power, Precision Operational Amplifier 8-SOIC -40 to 85
OPA161x SoundPlus High-Performance, Bipolar-Input Audio Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 27 авг 2014
51 предложений от 21 поставщиков
OPA1611AID
от 71 ₽
ЗУМ-СМД
OPA1611AID
79 ₽
Элитан
OPA1611AID
217 ₽
OPA1611AID
от 1 521 ₽
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаOPA1611A
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesBurr-Brownв„ў Audio
АрхитектураBipolar
CMRR(Min)110 дБ
CMRR(Typ)120 дБ
GBW(Typ)40 МГц
Input Bias Current(Max)250000 pA
Iq per channel(Max)4.5 мА
Iq per channel(Typ)3.6 мА
Количество каналов1
Offset Drift(Typ)1 uV/C
Output Current(Typ)55 мА
Rail-to-RailOut
Slew Rate(Typ)27 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Feedback Plots Define Op Amp AC Performance
    PDF, 89 Кб, Файл опубликован: 27 сен 2000
    Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA1611 (2)
На английском языке: Datasheet Texas Instruments OPA1611AID
