Datasheet Texas Instruments OPA124UE4 — Даташит
Серия | OPA124 |
Модель | OPA124UE4 |
Малошумящий прецизионный операционный усилитель Difet 8-SOIC от -25 до 85
Low Noise Precision Difet® Operational Amplifier datasheet
PDF, 287 Кб, Файл опубликован: 27 сен 2000
![]() 10 предложений от 10 поставщиков TEXAS INSTRUMENTS OPA124UE4 Operational Amplifier, Single, 1 Amplifier, 1.5MHz, 1.6V/µs, ± 5V to ± 18V, SOIC, 8Pins | |||
OPA124UE4 Texas Instruments | 375 ₽ | ||
OPA124UE4 Micross Components | 472 ₽ | ||
OPA124UE4 Texas Instruments | 789 ₽ | ||
OPA124UE4 Texas Instruments | 833 ₽ |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | 124U | OPA |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 86 дБ |
CMRR(Typ) | 100 дБ |
GBW(Typ) | 1 МГц |
Input Bias Current(Max) | 1 pA |
Iq per channel(Max) | 3.5 мА |
Iq per channel(Typ) | 2.5 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 1 uV/C |
Рабочий диапазон температур | от -25 до 85 C |
Output Current(Typ) | 40 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | Out |
Rating | Catalog |
Slew Rate(Typ) | 1.6 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 8 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.25 мВ |
- Diode-Connected FET Protects Op AmpsPDF, 49 Кб, Файл опубликован: 2 окт 2000
Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step. - Comparison of Noise Performance of FET Transimpedence Amp/Switched IntegratorPDF, 66 Кб, Файл опубликован: 27 сен 2000
Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA124 (14)
