Datasheet LMV934MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.5 МГц, 0.42 В/мкс, SOIC-14 — Даташит
National Semiconductor LMV934MA/NOPB
Наименование модели: LMV934MA/NOPB
35 предложений от 18 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMV934MA/NOPB Operational Amplifier, Quad, 4 Amplifier, 1.5MHz, 0.42V/µs, 1.8V to 5.5V, SOIC, 14Pins
LMV934MA/NOPB
194 ₽
ЭИК
LMV934MA/NOPB
от 316 ₽
LMV934MA/NOPB
от 368 ₽
LMV934MA/NOPB
Описание: ИС, операционный усилитель, 1.5 МГц, 0.42 В/мкс, SOIC-14
data sheetСкачать Data Sheet
LMV931 Single/LMV932 Dual/LMV934 Quad 1.8V, RRIO Operational Amplifiers
LMV931 Single/LMV932 Dual/ LMV934 Quad 1.8V, RRIO Operational Amplifiers
General Description
The LMV931/LMV932/LMV934 are low voltage, low power operational amplifiers.
LMV931/LMV932/LMV934 operate from +1.8V to +5.5V supply voltages and have rail-to-rail input and output. LMV931/LMV932/LMV934 input common mode voltage extends 200mV beyond the supplies which enables user enhanced functionality beyond the supply voltage range. The output can swing rail-to-rail unloaded and within 105mV from the rail with 600 load at 1.8V supply. The LMV931/ LMV932/LMV934 are optimized to work at 1.8V which make them ideal for portable two-cell battery powered systems and single cell Li-Ion systems. LMV931/LMV932/LMV934 exhibit excellent speed-power ratio, achieving 1.4MHz gain bandwidth product at 1.8V supply voltage with very low supply current. The LMV931/LMV932/ LMV934 are capable of driving a 600 load and up to 1000pF capacitiv
  • Тип ОУ: Low Voltage
  • Количество усилителей: 4
  • Полоса частот: 1.5 МГц
  • Скорость нарастания: 0.42 В/мкс
  • Диапазон напряжения питания: 1.8 В ... 5.5 В
  • Тип корпуса: SOIC
  • Количество выводов: 14
На английском языке: Datasheet LMV934MA/NOPB - National Semiconductor IC, OP-AMP, 1.5 MHz, 0.42 V/µs, SOIC-14
