Datasheet LMV772MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 3.5 МГц, 5 В/мкс, MSOP-8 — Даташит
National Semiconductor LMV772MM/NOPB
Наименование модели: LMV772MM/NOPB
34 предложений от 17 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMV772MM/NOPB Operational Amplifier, Dual, 2 Amplifier, 3.5MHz, 1.4V/µs, 2.7V to 5.5V, MSOP, 8Pins
LMV772MM/NOPB
от 34 ₽
LMV772MM/NOPB
49 ₽
LMV772MM/NOPB
от 69 ₽
LMV772MM/NOPB
100 ₽
Описание: ИС, операционный усилитель, 3.5 МГц, 5 В/мкс, MSOP-8
data sheetСкачать Data Sheet
LMV771/LMV772/LMV772Q/LMV774 Single/Dual/Quad, Low Offset, Low Noise, RRO Operational Amplifiers
LMV771/LMV772/LMV772Q/ LMV774 Single/Dual/Quad, Low Offset, Low Noise, RRO Operational Amplifiers
General Description
The LMV771/LMV772/LMV772Q/LMV774 are Single, Dual, and Quad low noise precision operational amplifiers intended for use in a wide range of applications.
Other important characteristics of the family include: an extended operating temperature range of -40°C to 125°C, the tiny SC70-5 package for the LMV771, and low input bias current. The extended temperature range of -40°C to 125°C allows the LMV771/LMV772/LMV772Q/LMV774 to accommodate a broad range of applications. The LMV771 expands National Semiconductor's Silicon DustTM amplifier portfolio offering enhancements in size, speed, and power savings. The LMV771/ LMV772/LMV772Q/LMV774 are guaranteed to operate over the voltage range of 2.7V to 5.0V and all have rail-to-rail output. The LMV771/LMV772/LMV772Q/LMV774 family is de
  • Тип ОУ: Low Offset Voltage
  • Количество усилителей: 2
  • Полоса частот: 3.5 МГц
  • Скорость нарастания: 5 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • Тип корпуса: MSOP
  • Количество выводов: 8
На английском языке: Datasheet LMV772MM/NOPB - National Semiconductor IC, OP-AMP, 3.5 MHz, 5 V/µs, MSOP-8
Реклама
Реклама. ООО «ТМ Электроникс»
ИНН 7806544094
