Источники питания Keen Side
Datasheet LMV721M5/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 10 МГц, 5.25 В/мкс, SOT-23-5 — Даташит
National Semiconductor LMV721M5/NOPB
Наименование модели: LMV721M5/NOPB
27 предложений от 20 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMV721M5/NOPB Operational Amplifier, Single, 1 Amplifier, 10MHz, 5.25V/µs, 2.2V to 5.5V, SOT-23, 5Pins
LMV721M5/NOPB
52 ₽
T-electron
LMV721M5/NOPB
59 ₽
IC Home
LMV721M5/NOPB
155 ₽
ЗУМ-СМД
LMV721M5/NOPB
Описание: ИС, операционный усилитель, 10 МГц, 5.25 В/мкс, SOT-23-5
data sheetСкачать Data Sheet
LMV721/LMV722 10MHz, Low Noise, Low Voltage, and Low Power Operational Amplifier
July 2, 2008
General Description
The LMV721 (Single) and LMV722 (Dual) are low noise, low voltage, and low power op amps, that can be designed into a wide range of applications.
The LMV721/LMV722 has a unity gain bandwidth of 10MHz, a slew rate of 5V/us, and a quiescent current of 930uA/amplifier at 2.2V. The LMV721/722 are designed to provide optimal performance in low voltage and low noise systems. They provide rail-to-rail output swing into heavy loads. The input commonmode voltage range includes ground, and the maximum input offset voltage are 3.5mV (Over Temp.) for the LMV721/ LMV722. Their capacitive load capability is also good at low supply voltages. The operating range is from 2.2V to 5.5V. The chip is built with National's advanced Submicron SiliconGate BiCMOS process. The single version, LMV721, is available in 5
  • Тип ОУ: Low Power
  • Количество усилителей: 1
  • Полоса частот: 10 МГц
  • Скорость нарастания: 5.25 В/мкс
  • Диапазон напряжения питания: 2.2 В ... 5.5 В
  • Тип корпуса: SOT-23
  • Количество выводов: 5
На английском языке: Datasheet LMV721M5/NOPB - National Semiconductor IC, OP-AMP, 10 MHz, 5.25 V/µs, SOT-23-5
