Datasheet LMV342MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 1 В/мкс, MSOP-8 — Даташит
Наименование модели: LMV342MM/NOPB
30 предложений от 15 поставщиков TEXAS INSTRUMENTS LMV342MM/NOPB Operational Amplifier, Dual, 2 Amplifier, 1MHz, 1V/µs, 2.7V to 5.5V, MSOP, 8Pins | |||
LMV342MM/NOPB Texas Instruments | от 42 ₽ | ||
LMV342MM/NOPB National Semiconductor | 52 ₽ | ||
LMV342MM/NOPB National Semiconductor | 61 ₽ | ||
LMV342MM/NOPB Texas Instruments | по запросу |
Описание: ИС, операционный усилитель, 1 МГц, 1 В/мкс, MSOP-8
LMV341/LMV342/LMV344 Single with Shutdown/Dual/Quad General Purpose, 2.7V, Rail-to-Rail Output, 125°C, Operational Amplifiers
January 25, 2008
General Description
The LMV341/LMV342/LMV344 are single, dual, and quad low voltage, low power Operational Amplifiers.
They are designed specifically for low voltage portable applications. Other important product characteristics are low input bias current, railto-rail output, and wide temperature range. The patented class AB turnaround stage significantly reduces the noise at higher frequencies, power consumption, and offset voltage. The PMOS input stage provides the user with ultra-low input bias current of 20fA (typical) and high input impedance. The industrial-plus temperature range of -40°C to 125°C allows the LMV341/LMV342/LMV344 to accommodate a broad range of extended environment applications. LMV341 expands Nati
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 1 МГц
- Скорость нарастания: 1 В/мкс
- Диапазон напряжения питания: 2.7 В ... 5.5 В
- Тип корпуса: MSOP
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +125°C
