Datasheet LM8272MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 13 МГц, 12 В/мкс, SOIC-8 — Даташит
National Semiconductor LM8272MM/NOPB
Наименование модели: LM8272MM/NOPB
30 предложений от 19 поставщиков
LM8272MM/NOPB
112 ₽
LM8272MM/NOPB
163 ₽
LM8272MM/NOPB
Allelco
LM8272MM/NOPB
Описание: ИС, операционный усилитель, 13 МГц, 12 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LM8272 Dual RRIO, High Output Current & Unlimited Cap Load Op Amp in Miniature Package
December 2002
General Description
The LM8272 is a Rail-to-Rail input and output Op Amp which can operate with a wide supply voltage range.
This device has high output current drive, greater than Rail-to-Rail input common mode voltage range, unlimited capacitive load drive capability while requiring only 0.95mA/channel supply current. It is specifically designed to handle the requirements of flat panel TFT panel VCOM driver applications as well as being suitable for other low power, and medium speed applications which require ease of use and enhanced performance over existing devices. Greater than Rail-to-Rail input common mode voltage range with 50dB of Common Mode Rejection, allows high side and low side sensing, among many applications, without having any concerns over exceeding the range and no compromise in a
  • Тип ОУ: High Current
  • Количество усилителей: 1
  • Полоса частот: 13 МГц
  • Скорость нарастания: 12 В/мкс
  • Диапазон напряжения питания: 2.5 В ... 24 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LM8272MM/NOPB - National Semiconductor IC, OP-AMP, 13 MHz, 12 V/µs, SOIC-8
