Datasheet LM358AMX/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, SOIC-8 — Даташит
Наименование модели: LM358AMX/NOPB
![]() 42 предложений от 23 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM358AMX/NOPB Operational Amplifier, Dual, 2 Amplifier, 1MHz, 0.1V/µs, 3V to 32V, ± 1.5V to ± 16V,... | |||
LM358AMX/NOPB Texas Instruments | 34 ₽ | ||
LM358AMX/NOPB Texas Instruments | 50 ₽ | ||
LM358AMX/NOPB Texas Instruments | от 70 ₽ | ||
LM358AMX/NOPB National Semiconductor | по запросу |
Описание: ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, SOIC-8
LM158/LM258/LM358/LM2904 Low Power Dual Operational Amplifiers
October 2005
General Description
The LM158 series consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM158 series can be directly operated off of the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional ± 15V power supplies. The LM358 and LM2904 are available in a chip s
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 1 МГц
- Скорость нарастания: 0.1 В/мкс
- Диапазон напряжения питания: 3 В ... 32 В
- Тип корпуса: SOIC
- Количество выводов: 8
- Рабочий диапазон температрур: 0°C ... +70°C
