Datasheet LMV981MG/NOPB - National Semiconductor Даташит ИС, операционный усилитель R-R I/O W/SD SC-70-6 — Даташит
Наименование модели: LMV981MG/NOPB
![]() 33 предложений от 16 поставщиков TEXAS INSTRUMENTS LMV981MG/NOPB Operational Amplifier, Single, 1 Amplifier, 1.4MHz, 0.42V/µs, 1.8V to 5V, SC-70, 6Pins | |||
LMV981MG/NOPB Texas Instruments | 44 ₽ | ||
LMV981MG/NOPB National Semiconductor | 83 ₽ | ||
LMV981MG/NOPB Texas Instruments | от 126 ₽ | ||
LMV981MG/NOPB Texas Instruments | по запросу |
Описание: ИС, операционный усилитель R-R I/O W/SD SC-70-6
LMV981 Single / LMV982 Dual 1.8V, RRIO Operational Amplifiers with Shutdown
November 2005
General Description
LMV981/LMV982 are low voltage, low power operational amplifiers.
LMV981/LMV982 are guaranteed to operate from +1.8V to +5.0V supply voltages and have rail-to-rail input and output. LMV981/LMV982 input common mode voltage extends 200mV beyond the supplies which enables user enhanced functionality beyond the supply voltage range. The output can swing rail-to-rail unloaded and within 105mV from the rail with 600 load at 1.8V supply. LMV981/ LMV982 are optimized to work at 1.8V which make them ideal for portable two-cell battery powered systems and single cell Li-Ion systems. LMV981/LMV982 offer a shutdown pin that can be used to disable the device and reduce the supply current. The device is in shutdown when the SHDN-pin = low. The output will be high impedance in shutdown. LMV981/LMV982 exhibit excellen
- Тип ОУ: Low Voltage
- Количество усилителей: 1
- Полоса частот: 1.4 МГц
- Скорость нарастания: 0.42 В/мкс
- Диапазон напряжения питания: 1.8 В ... 5 В
- Тип корпуса: SC-70
- Количество выводов: 6
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 981
- Добротность: 1.5 МГц
- Рабочий диапазон температрур: -40°C ... +125°C
- Способ монтажа: SMD
